주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech MX Mechanical Mini Akku tauschen
필요한 것
    1. Logitech MX Mechanical Mini Akku tauschen, Akku: 1 단계, 이미지 1개 중 1개
      • Entferne den Aufkleber auf der Rückseite des Gerätes in Höhe der linken unteren Ecke.
      • Tue das gleiche mit der rechten Ecke.
      댓글 쓰기
    2. Logitech MX Mechanical Mini Akku tauschen: 2 단계, 이미지 1개 중 1개
      • Sei vorsichtig beim Ausbau der Klappe, da die 3 Halter leicht abbrechen können.
      댓글 쓰기
    3. Logitech MX Mechanical Mini Akku tauschen: 3 단계, 이미지 1개 중 1개
      • Ziehe das Kabel ab.
      댓글 쓰기
    4. Logitech MX Mechanical Mini Akku tauschen: 4 단계, 이미지 1개 중 1개
      • Der Akku ist mit doppelseitigem Klebeband am Gehäuse befestigt. Hebe ihn vorsichtig mit einem Spatel oder breiten Schraubendreher ab.
      댓글 쓰기
결론
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Stefan Pörsel
회원 가입일: 12/09/23
332 평판
안내서 1개를 작성함
4가이드 댓글
Thank you for posting this. I just picked this keyboard up today and decided to watch a disassembly video on YouTube during which the individual reported that the battery was sealed into the back plate of the keyboard which caused me to consider returning it to the store. Clearly he didn't look under the label. Glad to see it's at least serviceable!
Jared S. - 답글 공유
Thanks for posting this. This guide also works for the MX Mechanical full-sized keyboard.
Francis Bell - 답글 공유
Where'd you find the replacement battery? Google search only seems to turn up some sketchy looking sites.
Christopher Larrieu - 답글 공유
Location dimensions are 8,5 x 5 x 0,5 cm.
gaMiNOos - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 15
지난 30일: 122
전체 시간: 4,094
