주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech Mouse G302 Disassembly
필요한 것
    1. Logitech Mouse G302 Disassembly, Open the case: 1 단계, 이미지 2개 중 1개 Logitech Mouse G302 Disassembly, Open the case: 1 단계, 이미지 2개 중 2개
      • Turn the mouse over to access the bottom.
      • Using a scalpel, pick, or similar tool, peel off the front and rear soles (slide pads) on the bottom of the mouse. This exposes three screws.
      • Using a Phillips #0 driver, remove the three screws circled in red.
      • Use care to salvage as much of the sole adhesive as possible, in order to reuse it. If, however the adhesive is inadequate on reassemby, contact cement is a good substitute.
      • Carefully separate the two halves of the case. Light prying may be required. If you examine the second photo you can see one of the plastic retaining tabs on the front of the top half. A pick or similar tool prove helpful without marring the case.
      • Remove the three Phillips PH000 screws circled in orange; The PCB can then be removed for inspection and repair.
      댓글 쓰기
    2. Logitech Mouse G302 Disassembly, Switch replacement: 2 단계, 이미지 2개 중 1개 Logitech Mouse G302 Disassembly, Switch replacement: 2 단계, 이미지 2개 중 2개
      • The switch manufacturer is Omron, part number: D2FC-F-7N. The switches have three lead pins, two of which are used.
      • My experience was one switch working intermittently. In such a case, I recommend replacing both the left and right switches.
      댓글 쓰기
    3. Logitech Mouse G302 Disassembly, Switch information: 3 단계, 이미지 1개 중 1개
      • This may be helpful in finding the correct or compatible replacement i.e. online vendors such as AliExpress.
      • What I used as a successful replacement: RS Components Stock No. 682-1519 microswitch. Manufactured by Omron—part number: D2F-F.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
Carsten Dahl Hjarup
회원 가입일: 11/04/13
3,128 평판
안내서 9개를 작성함
2가이드 댓글
what is the name and type of switch number 3 / sw3
Yanuar Arifiyanto - 답글 공유
Did the job on my own mouse just tonight. The screws are actually Phillips #000, not #0 as indicated in the guide.
Michael G - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 30
지난 30일: 92
전체 시간: 7,564
