주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이 번역은 원본 안내서의 최신 업데이트를 반영하지 않을 수 있습니다. 번역 업데이트를 돕거나 아니면 원본 안내서 보기를 참조하세요.
Logitech Performance MX Left Click Repair
필요한 것
  1. Logitech Performance MX Left Click Repair, Turn off the mouse and remove the battery: 1 단계, 이미지 1개 중 1개
    • On the back of the mouse, slide the power switch so that the red area is showing to turn off the mouse. Pry open the panel on the bottom to remove the battery.
    댓글 쓰기
  2. Logitech Performance MX Left Click Repair, Remove the 3 pads: 2 단계, 이미지 1개 중 1개
    • To access the screws necessary to open the mouse, you must remove the pads on the bottom of the mouse. Use a sharp tool such as an iFixit Jimmy tool or an X-acto knife to separate the pad from the case. Each pad has two layers. Ideally, both should remain attached, but this is hard to achieve.
    댓글 쓰기
  3. Logitech Performance MX Left Click Repair, Remove the 4 screws: 3 단계, 이미지 1개 중 1개
    • Use a 00 Phillips-Head screwdriver to remove the screws at the bottom of the mouse.
    댓글 쓰기
  4. Logitech Performance MX Left Click Repair, Remove the upper part of the mouse: 4 단계, 이미지 3개 중 1개 Logitech Performance MX Left Click Repair, Remove the upper part of the mouse: 4 단계, 이미지 3개 중 2개 Logitech Performance MX Left Click Repair, Remove the upper part of the mouse: 4 단계, 이미지 3개 중 3개
    • Slide the bottom laterally while lifting.
    댓글 쓰기
  5. Logitech Performance MX Left Click Repair, (optional) remove the connector: 5 단계, 이미지 1개 중 1개
    • This step isn't necessary, but it makes it easier to work on the mouse.
    댓글 쓰기
  6. Logitech Performance MX Left Click Repair, (optional) put a bit of tape on top of the microswitch: 6 단계, 이미지 1개 중 1개
    • This helps to avoid losing the white piece.
    댓글 쓰기
  7. Logitech Performance MX Left Click Repair, Remove the multiswitch top: 7 단계, 이미지 2개 중 1개 Logitech Performance MX Left Click Repair, Remove the multiswitch top: 7 단계, 이미지 2개 중 2개
    • Use your spudger to push the vertical front part of the multiswitch outwards to unhook the top part of the switch casing.
    댓글 쓰기
  8. Logitech Performance MX Left Click Repair, Flatten the metallic piece: 8 단계, 이미지 2개 중 1개 Logitech Performance MX Left Click Repair, Flatten the metallic piece: 8 단계, 이미지 2개 중 2개
    • Flatten the metallic piece of the multiswitch (it will probably be curved upward) until you get a neat "click" sound.
    댓글 쓰기
결론
To reassemble the mouse, follow the instructions in the reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 12명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
94%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
4다른 기여자 명과 함께
Samuel Colin
회원 가입일: 03/26/20
717 평판
안내서 2개를 작성함
8가이드 댓글
merci , ca vient de sauver ma Revolution
Clement Renaut - 답글 공유
Avec plaisir. J'en suis ravi :)
Samuel Colin - 답글 공유
Thank you, this worked flawlessly. Your time and effort is well appreciated.
Kenji Lum - 답글 공유
Thank you so much. My left click often unregisters incorrectly. If not for step 7 and 8, I wouldn't have opened the multiswitch top and clean the contact point. Seems to work perfectly normal now. It'd be a waste to throw away the whole item just because of a tiny defective component. Thanks again for helping me fixed it.
Thuan Chau - 답글 공유
@Kenji @thuan: I'm glad I could help. Thanks for your comments!
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 69
지난 30일: 254
전체 시간: 25,480
