주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech R400 Presenter Disassembly
필요한 것
    1. Logitech R400 Presenter Disassembly, Remove the unnecessary parts: 1 단계, 이미지 2개 중 1개 Logitech R400 Presenter Disassembly, Remove the unnecessary parts: 1 단계, 이미지 2개 중 2개
      • Remove the USB-Receiver.
      • Open the battery compartment.
      • Remove the batteries.
      댓글 쓰기
    2. Logitech R400 Presenter Disassembly, Remove the sticker: 2 단계, 이미지 1개 중 1개
      • To remove the sticker that's covering the next screws, I used a small slot screwdriver and carefully inserted it at the shown position. There is a little notch here that guides you in.
      댓글 쓰기
    3. Logitech R400 Presenter Disassembly, Remove 2 screws: 3 단계, 이미지 1개 중 1개
      • Below the sticker we have two Philips screws (red). Unscrew them.
      • Edit according to Simon (see comment): In the yellow slot there is a tab that is to be pushed down to unlatch it. If you insert a pick in the seam between the top and the bottom half of the device it should open easily when downward pressure is applied to the latch..
      • Now carefully pry apart the two halves of the cover, starting from the side of the battery compartment.
      댓글 쓰기
    4. Logitech R400 Presenter Disassembly, Just another screw.: 4 단계, 이미지 1개 중 1개
      • The green board is where all the application logic is in, so don't scratch it.
      • There is one single screw. Unscrew it.
      • Carefully take out the green board. The connectors for the batteries are attached here, don't break them (though they are quite sturdy). Step 6 has an image how the board looks from the other side.
      댓글 쓰기
    5. Logitech R400 Presenter Disassembly, Finished: 5 단계, 이미지 1개 중 1개
      • This should be the end product.
      댓글 쓰기
    6. Logitech R400 Presenter Disassembly, Not actually part of the disassembly...: 6 단계, 이미지 2개 중 1개 Logitech R400 Presenter Disassembly, Not actually part of the disassembly...: 6 단계, 이미지 2개 중 2개
      • The reason why I disassembled my presenter was, that the laser diode (red) did not project out of the case any more. You can clearly see the laser being at a very odd angle. I can not imagine how that happened.
      • The yellow marker shows the battery connectors you are not supposed to break in step 4.
      • In the last image you see the "fixed" laser diode. I just gently pushed it down, now it's working again.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 16명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Stephan
회원 가입일: 08/13/16
1,373 평판
안내서 2개를 작성함
14가이드 댓글
excellent description. it works immediately.
wafiq shafiq - 답글 공유
well done … I did not expect to dissamble an electronic device and it is going to work again :)
god bless you mate!
Filip Liebert - 답글 공유
R800 disassembly is indeed similar, although the sticker is in two parts. The battery image should also be removed.
Dave Geerardyn - 답글 공유
Seems that Logitech has produced several generations or versions and calls them call R400. Mine looks all different inside, for example the laser diode cannot bend any longer, it has got its own bolting-down-plate and two flex cables to connect it. My PID is WD502XM. Mine was purchased in Denmark or Sweden some time in 2014 or 2015. My laser stopped working too (while the rest of the functionality is still working). How can we set up different versions on ifixit, so that we will not confuse versions and discussions/instructions? I am new here, joined today.
Martin - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 22
지난 30일: 112
전체 시간: 17,546
