주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech Signature M650 L Scroll Wheel Assembly Replacement
필요한 것
    1. Logitech Signature M650 L Scroll Wheel Assembly Replacement, Scroll Wheel Assembly: 1 단계, 이미지 3개 중 1개 Logitech Signature M650 L Scroll Wheel Assembly Replacement, Scroll Wheel Assembly: 1 단계, 이미지 3개 중 2개 Logitech Signature M650 L Scroll Wheel Assembly Replacement, Scroll Wheel Assembly: 1 단계, 이미지 3개 중 3개
      • Slide the battery compartment cover downward and lift it away from the mouse.
      댓글 쓰기
    2. Logitech Signature M650 L Scroll Wheel Assembly Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the AA battery from the battery compartment.
      댓글 쓰기
    3. Logitech Signature M650 L Scroll Wheel Assembly Replacement: 3 단계, 이미지 2개 중 1개 Logitech Signature M650 L Scroll Wheel Assembly Replacement: 3 단계, 이미지 2개 중 2개
      • Remove the USB receiver from its storage slot inside the battery compartment.
      댓글 쓰기
    4. Logitech Signature M650 L Scroll Wheel Assembly Replacement: 4 단계, 이미지 1개 중 1개
      • Use a Phillips #000 screwdriver to remove the two screws securing the internal frame.
      댓글 쓰기
    5. Logitech Signature M650 L Scroll Wheel Assembly Replacement: 5 단계, 이미지 2개 중 1개 Logitech Signature M650 L Scroll Wheel Assembly Replacement: 5 단계, 이미지 2개 중 2개
      • Gently lift the top shell away from the mouse body.
      • Do not remove it completely, as it is still connected to the base by a cable.
      댓글 쓰기
    6. Logitech Signature M650 L Scroll Wheel Assembly Replacement: 6 단계, 이미지 1개 중 1개
      • Use a Phillips #000 screwdriver to remove the two screws securing the scroll wheel assembly.
      댓글 쓰기
    7. Logitech Signature M650 L Scroll Wheel Assembly Replacement: 7 단계, 이미지 2개 중 1개 Logitech Signature M650 L Scroll Wheel Assembly Replacement: 7 단계, 이미지 2개 중 2개
      • Lift the scroll wheel assembly out of the mouse and install the replacement assembly in the same position.
      댓글 쓰기
    8. Logitech Signature M650 L Scroll Wheel Assembly Replacement: 8 단계, 이미지 1개 중 1개
      • Replace the two Phillips #000 screws to secure the scroll wheel assembly.
      댓글 쓰기
    9. Logitech Signature M650 L Scroll Wheel Assembly Replacement: 9 단계, 이미지 1개 중 1개
      • Align the top shell with the base and press down along the edges until it snaps into place.
      댓글 쓰기
    10. Logitech Signature M650 L Scroll Wheel Assembly Replacement: 10 단계, 이미지 1개 중 1개
      • Use a Phillips #000 screwdriver to reinstall the two internal screws.
      댓글 쓰기
    11. Logitech Signature M650 L Scroll Wheel Assembly Replacement: 11 단계, 이미지 3개 중 1개 Logitech Signature M650 L Scroll Wheel Assembly Replacement: 11 단계, 이미지 3개 중 2개 Logitech Signature M650 L Scroll Wheel Assembly Replacement: 11 단계, 이미지 3개 중 3개
      • Insert the AA battery, reinstall the USB receiver, and slide the battery compartment cover back into place.
      댓글 쓰기
    12. Logitech Signature M650 L Scroll Wheel Assembly Replacement: 12 단계, 이미지 1개 중 1개
      • Your mouse is now fully reassembled.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Angela Gerasimova
회원 가입일: 01/08/26
205 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 24
지난 30일: 69
전체 시간: 248
