주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech Spotlight Battery Replacement
필요한 것
    1. Logitech Spotlight Battery Replacement, Disassembling the bottom case: 1 단계, 이미지 1개 중 1개
      • Remove the lower casing.
      • There doesn't seem to be a way of removing that part of the casing without breaking it, so you may have to break the plastic parts.
      댓글 쓰기
    2. Logitech Spotlight Battery Replacement: 2 단계, 이미지 1개 중 1개
      • Unscrew the screws next to the charging port.
      댓글 쓰기
    3. Logitech Spotlight Battery Replacement, Removing the top cover: 3 단계, 이미지 1개 중 1개
      • Remove the top cover. Watch out for the glue.
      댓글 쓰기
    4. Logitech Spotlight Battery Replacement, Removing the back plate: 4 단계, 이미지 3개 중 1개 Logitech Spotlight Battery Replacement, Removing the back plate: 4 단계, 이미지 3개 중 2개 Logitech Spotlight Battery Replacement, Removing the back plate: 4 단계, 이미지 3개 중 3개
      • Remove the back plate.
      • Be careful not to break the plastic latch indicated in the image and watch out for glue.
      • Undo the screws near the top of the case. Then carefully slide the internal plastic case upward to remove it.
      • On the board underneath, remove 3 screws.
      • Watch out for the plastic latch.
      댓글 쓰기
    5. Logitech Spotlight Battery Replacement, Removing the battery: 5 단계, 이미지 2개 중 1개 Logitech Spotlight Battery Replacement, Removing the battery: 5 단계, 이미지 2개 중 2개
      • Carefully remove the board to gain access to the battery.
      • Remove and replace the battery.
      • Once reassembled, the device should be working again.
      댓글 쓰기
결론
To reassemble your device, follow the steps in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
Sae Hee
회원 가입일: 05/06/20
93 평판
안내서 1개를 작성함
10가이드 댓글
I dont't think this is an easy iFixit instruction. It's rather mid or hard especially since you have to break plastic parts to even access the screws. It might make sense to change the difficulty on this one :D @mariaparker
nils - 답글 공유
@fixnils you are completely right, that was a mistake on my part! Thanks for noticing :)
Maria Parker - 답글 공유
@mariaparker could we maybe add the specifications of the Lithium battery to the repair manual?
I could provide an image from my logitech spotlight to help with that.
Users are coming back again and again to ask the same question about the battery specification and the battery size.
nils - 답글 공유
At step 1, I was able to twist and push a strong but thin screwdriver (Philips 000) through the plastic parts which would otherwise block access to the screws. By angling the screwdriver slightly the screws can be released without breaking the plastic completely, so you still have the retention of the usb dongle - although obviously this isn't essential.
If you have to heat-shrink connection of the original plug and new battery wires they may be too bulky for the board to go back properly in the carrier. I had to cut away small bits of ribs on the carrier
Thanks for the useful instructions
Stephen
Stephen - 답글 공유
Hi,
please what are the dimensions of the 90mAh battery? Would Like to prchavé the battery before opening of the device. Thanks, Peter
Peter - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 56
지난 30일: 196
전체 시간: 12,342
