주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech UE Boom USB Port Replacement
필요한 것
    1. Logitech UE Boom USB Port Replacement, D-ring: 1 단계, 이미지 1개 중 1개
      • Turn the device over. The D-ring will be on the left face of the speaker when viewing the device from this orientation.
      댓글 쓰기
    2. Logitech UE Boom USB Port Replacement: 2 단계, 이미지 2개 중 1개 Logitech UE Boom USB Port Replacement: 2 단계, 이미지 2개 중 2개
      • Lift the handle on the D-ring and unscrew it.
      • Remove the D-ring.
      댓글 쓰기
    1. Logitech UE Boom USB Port Replacement, Bluetooth Adapter: 3 단계, 이미지 1개 중 1개
      • Any repairs made from this point forward will void your device's warranty.
      • Holding the speaker upright, wedge the metal spudger in between the casing and the speaker. Gently pry open the tabs as they are easily broken.
      댓글 쓰기
    2. Logitech UE Boom USB Port Replacement: 4 단계, 이미지 3개 중 1개 Logitech UE Boom USB Port Replacement: 4 단계, 이미지 3개 중 2개 Logitech UE Boom USB Port Replacement: 4 단계, 이미지 3개 중 3개
      • Find the part of the casing that covers the volume controls. Wedge the metal spudger under this and pry open all of the tabs as in the previous step.
      • Repeat for the bottom of the speaker and pry the casing open with your fingers.
      댓글 쓰기
    3. Logitech UE Boom USB Port Replacement: 5 단계, 이미지 2개 중 1개 Logitech UE Boom USB Port Replacement: 5 단계, 이미지 2개 중 2개
      • Using the Phillips J0 head screwdriver, unscrew the four silver 9 mm screws.
      • Do the same for the two black 7 mm screws.
      댓글 쓰기
    4. Logitech UE Boom USB Port Replacement: 6 단계, 이미지 3개 중 1개 Logitech UE Boom USB Port Replacement: 6 단계, 이미지 3개 중 2개 Logitech UE Boom USB Port Replacement: 6 단계, 이미지 3개 중 3개
      • This next step involves the use of a hot soldering iron. Remember to be careful during this step since it can be easy to burn yourself.
      • Using a soldering iron, de-solder the two ends of the switch plate. Desolder the two terminals on headphone jack side first, as the middle connection is notched and should be slid out when molten.
      댓글 쓰기
    5. Logitech UE Boom USB Port Replacement: 7 단계, 이미지 1개 중 1개
      • With the switch plate disconnected, remove it and your device should now look like this.
      댓글 쓰기
    1. Logitech UE Boom USB Port Replacement, Lithium Battery: 8 단계, 이미지 1개 중 1개
      • With a metal spudger, pry open the tabs on the speaker sleeve along the length of the speaker.
      댓글 쓰기
    2. Logitech UE Boom USB Port Replacement: 9 단계, 이미지 1개 중 1개
      • Use a plastic opening tool to pry the sleeve off from the bottom of the speaker.
      댓글 쓰기
    3. Logitech UE Boom USB Port Replacement: 10 단계, 이미지 3개 중 1개 Logitech UE Boom USB Port Replacement: 10 단계, 이미지 3개 중 2개 Logitech UE Boom USB Port Replacement: 10 단계, 이미지 3개 중 3개
      • Peel off the sleeve.
      댓글 쓰기
    4. Logitech UE Boom USB Port Replacement: 11 단계, 이미지 2개 중 1개 Logitech UE Boom USB Port Replacement: 11 단계, 이미지 2개 중 2개
      • Use a Phillips 1 screwdriver to unscrew the eight black 14 mm screws along the length of the casing.
      댓글 쓰기
    5. Logitech UE Boom USB Port Replacement: 12 단계, 이미지 2개 중 1개 Logitech UE Boom USB Port Replacement: 12 단계, 이미지 2개 중 2개
      • With the screws removed, pry open the casing to be able to get to the components inside.
      • Try prying the case open from one of the ends if that is easier.
      댓글 쓰기
    6. Logitech UE Boom USB Port Replacement: 13 단계, 이미지 2개 중 1개 Logitech UE Boom USB Port Replacement: 13 단계, 이미지 2개 중 2개
      • With a Phillips #00 screwdriver, unscrew two 5.6 mm screws from the rectangular shaped circuit board.
      댓글 쓰기
    7. Logitech UE Boom USB Port Replacement: 14 단계, 이미지 1개 중 1개
      • With the Phillips #2 screwdriver, unscrew the 9.9 mm screw from the larger circuit board surrounding the speaker.
      댓글 쓰기
    8. Logitech UE Boom USB Port Replacement: 15 단계, 이미지 1개 중 1개
      • Once all of the screws are gone, you should be able to remove the circuit boards and find the battery.
      댓글 쓰기
    9. Logitech UE Boom USB Port Replacement: 16 단계, 이미지 2개 중 1개 Logitech UE Boom USB Port Replacement: 16 단계, 이미지 2개 중 2개
      • Remove the battery by pulling it from the terminal as marked in the picture.
      댓글 쓰기
    1. Logitech UE Boom USB Port Replacement, USB Port: 17 단계, 이미지 2개 중 1개 Logitech UE Boom USB Port Replacement, USB Port: 17 단계, 이미지 2개 중 2개
      • Finally, after opening the speaker, locate the USB plate on the left face of the speaker and remove it from the motherboard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 9명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Sean Reilly
회원 가입일: 10/01/15
1,784 평판
안내서 2개를 작성함
Cal Poly, Team 4-1, Maness Fall 2015 Cal Poly, Team 4-1, Maness Fall 2015 회원
CPSU-MANESS-F15S4G1
4 회원들
안내서 34개를 작성함
13가이드 댓글
Hello,
does anyone know where to get new usb port, the logitech support didn´t really help.
cheers marius
kok0dora94 - 답글 공유
Same question as above, where can i buy a replacement USB port?
Corbett Hix - 답글 공유
i found 10 of them on ebay for 3-4 dollars
johnsonjohnsonalexalex - 답글 공유
Hi there , can you give me a link to Ebay where to find this port, thanks
katiecrow - 답글 공유
can you send me a link on ebay where to find this replacement port , thanks
katiecrow - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 37
지난 30일: 154
전체 시간: 38,806
