주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech UE Hyperboom Motherboard Replacement
필요한 것
  1. Logitech UE Hyperboom Motherboard Replacement, Handle: 1 단계, 이미지 2개 중 1개 Logitech UE Hyperboom Motherboard Replacement, Handle: 1 단계, 이미지 2개 중 2개
    • Unscrew the two black flat-top screws that attach the handle to the speaker with your hands.
    • You may need pliers to grip the screws.
    댓글 쓰기
  2. Logitech UE Hyperboom Motherboard Replacement, Top Panel: 2 단계, 이미지 2개 중 1개 Logitech UE Hyperboom Motherboard Replacement, Top Panel: 2 단계, 이미지 2개 중 2개
    • Use your hands to carefully pry the plastic cover off of the speaker.
    댓글 쓰기
  3. Logitech UE Hyperboom Motherboard Replacement: 3 단계, 이미지 3개 중 1개 Logitech UE Hyperboom Motherboard Replacement: 3 단계, 이미지 3개 중 2개 Logitech UE Hyperboom Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • Use a Phillips #0 screwdriver to remove the ten 11.7mm screws on the top panel.
    • Remove the top panel to access the internal components.
    • Use a metal spudger to completely disconnect the top panel.
    댓글 쓰기
  4. Logitech UE Hyperboom Motherboard Replacement, Speaker Drivers and Tweeters: 4 단계, 이미지 2개 중 1개 Logitech UE Hyperboom Motherboard Replacement, Speaker Drivers and Tweeters: 4 단계, 이미지 2개 중 2개
    • Use the Jimmy to pry the fiber mesh cover away from the speaker.
    • Take the fiber mesh off of the speaker completely.
    댓글 쓰기
  5. Logitech UE Hyperboom Motherboard Replacement: 5 단계, 이미지 3개 중 1개 Logitech UE Hyperboom Motherboard Replacement: 5 단계, 이미지 3개 중 2개 Logitech UE Hyperboom Motherboard Replacement: 5 단계, 이미지 3개 중 3개
    • Use the Phillips #0 screwdriver to unscrew the three 9.2mm screws around the tweeter speaker.
    • Use the Phillips #0 screwdriver to unscrew the eight 10.1mm screws around the speaker driver.
    • Use a metal spudger to pry the tweeter speaker out of the socket.
    댓글 쓰기
  6. Logitech UE Hyperboom Motherboard Replacement: 6 단계, 이미지 3개 중 1개 Logitech UE Hyperboom Motherboard Replacement: 6 단계, 이미지 3개 중 2개 Logitech UE Hyperboom Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Use a metal spudger to break the adhesive seal around the speaker driver.
    • Use your hands to push the speaker driver out of its socket.
    • A lot of force will be necessary, so it is possible the power and ground cables might disconnect from the force of dislodging the speaker driver.
    • Disconnect the power and ground cables from both the speaker driver and tweeter.
    댓글 쓰기
  7. Logitech UE Hyperboom Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Turn the speaker over, and face the two other speaker driver towards you.
    • Use the Phillips #0 screwdriver to remove the three 9.2mm screws around the speaker tweeter.
    • Use the Phillips #0 screwdriver to remove the eight 10.1mm screws around the speaker driver.
    댓글 쓰기
  8. Logitech UE Hyperboom Motherboard Replacement: 8 단계, 이미지 2개 중 1개 Logitech UE Hyperboom Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • Use a metal spudger to break the adhesive between the tweeter and the casing.
    • Disconnect the power and ground cables from the tweeter speaker to remove it completely.
    댓글 쓰기
  9. Logitech UE Hyperboom Motherboard Replacement: 9 단계, 이미지 3개 중 1개 Logitech UE Hyperboom Motherboard Replacement: 9 단계, 이미지 3개 중 2개 Logitech UE Hyperboom Motherboard Replacement: 9 단계, 이미지 3개 중 3개
    • Use your hands to remove the speaker driver from its socket.
    • Disconnect the power and ground cables to remove it completely.
    댓글 쓰기
  10. Logitech UE Hyperboom Motherboard Replacement, Motherboard: 10 단계, 이미지 2개 중 1개 Logitech UE Hyperboom Motherboard Replacement, Motherboard: 10 단계, 이미지 2개 중 2개
    • Disconnect all of the cables connected to the motherboard.
    댓글 쓰기
  11. Logitech UE Hyperboom Motherboard Replacement: 11 단계, 이미지 3개 중 1개 Logitech UE Hyperboom Motherboard Replacement: 11 단계, 이미지 3개 중 2개 Logitech UE Hyperboom Motherboard Replacement: 11 단계, 이미지 3개 중 3개
    • Use a Phillips #0 screwdriver to remove the four supporting 7.9mm screws.
    • Slide the motherboard out of the top of the speaker.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Ethan Abbott
회원 가입일: 03/10/26
859 평판
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 13
지난 30일: 55
전체 시간: 143
