주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech UE MegaBoom 3 Motherboard Replacement
필요한 것
    1. Logitech UE MegaBoom 3 Motherboard Replacement, General Disassembly: 1 단계, 이미지 2개 중 1개 Logitech UE MegaBoom 3 Motherboard Replacement, General Disassembly: 1 단계, 이미지 2개 중 2개
      • To access all internal components, first flip the speaker upwards to where you can see the base.
      • Place your blue iFixit opening picks inside the gap between the speaker and the base to act as a lever when opening the speaker.
      댓글 쓰기
    2. Logitech UE MegaBoom 3 Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Logitech UE MegaBoom 3 Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Logitech UE MegaBoom 3 Motherboard Replacement: 2 단계, 이미지 3개 중 3개
      • Using the flat head #4.5 screw driver, carefully lever and rotate the driver around the edge of the speaker to enlarge the gap further.
      • Here, it is ideal to use a spudger as opposed to the flathead screwdriver, however, the flathead makes it so much easier to pry off the cap.
      • Pry off the base of the speaker and remove the end cap.
      댓글 쓰기
    1. Logitech UE MegaBoom 3 Motherboard Replacement, Power Button Control Board: 3 단계, 이미지 3개 중 1개 Logitech UE MegaBoom 3 Motherboard Replacement, Power Button Control Board: 3 단계, 이미지 3개 중 2개 Logitech UE MegaBoom 3 Motherboard Replacement, Power Button Control Board: 3 단계, 이미지 3개 중 3개
      • Take off the fiber cover by prying it from the top of the speaker using the flathead 4.5 mm screwdriver.
      • After the cover is loosened, the cap can finally be pulled off.
      댓글 쓰기
    2. Logitech UE MegaBoom 3 Motherboard Replacement: 4 단계, 이미지 3개 중 1개 Logitech UE MegaBoom 3 Motherboard Replacement: 4 단계, 이미지 3개 중 2개 Logitech UE MegaBoom 3 Motherboard Replacement: 4 단계, 이미지 3개 중 3개
      • Remove the top half of the speaker using the 4.5 mm flat head screwdriver.
      • Now remove the top of the speaker by prying and releasing the tab around the cap using the same screwdriver.
      댓글 쓰기
    3. Logitech UE MegaBoom 3 Motherboard Replacement: 5 단계, 이미지 3개 중 1개 Logitech UE MegaBoom 3 Motherboard Replacement: 5 단계, 이미지 3개 중 2개 Logitech UE MegaBoom 3 Motherboard Replacement: 5 단계, 이미지 3개 중 3개
      • With the cap removed, using Phillips #0 screwdriver remove all four 2.0 mm screws to take off the control board.
      • Now you can replace the power button control board.
      댓글 쓰기
    1. Logitech UE MegaBoom 3 Motherboard Replacement, Speaker Driver: 6 단계, 이미지 2개 중 1개 Logitech UE MegaBoom 3 Motherboard Replacement, Speaker Driver: 6 단계, 이미지 2개 중 2개
      • Take of the metal rods by gently prying them out using the metal spudger.
      • Be sure to slide them out as gently as possible to prevent the rods from becoming damaged.
      댓글 쓰기
    2. Logitech UE MegaBoom 3 Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Logitech UE MegaBoom 3 Motherboard Replacement: 7 단계, 이미지 2개 중 2개
      • Once the rods are removed, you can pry it off and disconnect the speaker driver.
      • Repeat the same steps to disconnect the speaker driver on the other side of the speaker.
      댓글 쓰기
    1. Logitech UE MegaBoom 3 Motherboard Replacement, Passive Radiator: 8 단계, 이미지 2개 중 1개 Logitech UE MegaBoom 3 Motherboard Replacement, Passive Radiator: 8 단계, 이미지 2개 중 2개
      • Take off the metal rods by gently prying them out using the metal spudgers
      댓글 쓰기
    2. Logitech UE MegaBoom 3 Motherboard Replacement: 9 단계, 이미지 1개 중 1개
      • One the rods are removed you can pry it off and disconnect the passive radiator.
      • Repeat the same steps to disconnect the passive radiator on the other side of the speaker.
      댓글 쓰기
    1. Logitech UE MegaBoom 3 Motherboard Replacement, Motherboard: 10 단계, 이미지 3개 중 1개 Logitech UE MegaBoom 3 Motherboard Replacement, Motherboard: 10 단계, 이미지 3개 중 2개 Logitech UE MegaBoom 3 Motherboard Replacement, Motherboard: 10 단계, 이미지 3개 중 3개
      • Using the metal spudger, remove the volume control board to prevent any damage.
      • Remove the clear silicone cover to access the board.
      • Carefully pull off the board and disconnect it from the motherboard.
      댓글 쓰기
    2. Logitech UE MegaBoom 3 Motherboard Replacement: 11 단계, 이미지 2개 중 1개 Logitech UE MegaBoom 3 Motherboard Replacement: 11 단계, 이미지 2개 중 2개
      • Slide out the mother board gently.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Anthony Miles
회원 가입일: 09/04/23
1,021 평판
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 8
지난 30일: 41
전체 시간: 1,147
