주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech UE MegaBoom 3 USB Port Replacement
필요한 것
  1. Logitech UE MegaBoom 3 USB Port Replacement, General Disassembly: 1 단계, 이미지 2개 중 1개 Logitech UE MegaBoom 3 USB Port Replacement, General Disassembly: 1 단계, 이미지 2개 중 2개
    • To access all internal components, first flip the speaker upwards to where you can see the base.
    • Place your blue iFixit opening picks inside the gap between the speaker and the base to act as a lever when opening the speaker.
    댓글 쓰기
  2. Logitech UE MegaBoom 3 USB Port Replacement: 2 단계, 이미지 3개 중 1개 Logitech UE MegaBoom 3 USB Port Replacement: 2 단계, 이미지 3개 중 2개 Logitech UE MegaBoom 3 USB Port Replacement: 2 단계, 이미지 3개 중 3개
    • Using the flat head #4.5 screw driver, carefully lever and rotate the driver around the edge of the speaker to enlarge the gap further.
    • Here, it is ideal to use a spudger as opposed to the flathead screwdriver, however, the flathead makes it so much easier to pry off the cap.
    • Pry off the base of the speaker and remove the end cap.
    댓글 쓰기
  3. Logitech UE MegaBoom 3 USB Port Replacement, USB Port: 3 단계, 이미지 3개 중 1개 Logitech UE MegaBoom 3 USB Port Replacement, USB Port: 3 단계, 이미지 3개 중 2개 Logitech UE MegaBoom 3 USB Port Replacement, USB Port: 3 단계, 이미지 3개 중 3개
    • To remove the plastic frame that’s covering the charging board, use a Phillips #0 to remove both 2.4 mm screws.
    • Replace the charging port.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Anthony Miles
회원 가입일: 09/04/23
1,021 평판
안내서 6개를 작성함
3가이드 댓글
Thanks for the guide, this was very helpful!
Jason Doland - 답글 공유
How easy/hard would it be to upgrade the charging port to usb-c?
Nenad Tarlac - 답글 공유
This would be nearly impossible because micro-usb and usb type-c use different pinout (different number of pins...) and require different layout of the connection points on the charging PCB. And also the size of the usb-c socket is different.⏎
To do such modification it would require altering the charging PCB board, speaker housing (hole for the charging socket) and jumping (soldering very thin enamelled wires) from the usb-c connector to the different points on the charging PCB board.
Also this wouldn't increase the maximum charging speed, it would just be for the convenience of using one type-c cable with different modern devices.
Simon - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 21
지난 30일: 55
전체 시간: 1,141
