주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech UE MegaBoom Power Button Replacement
필요한 것
    1. Logitech UE MegaBoom Power Button Replacement, Outer Mesh: 1 단계, 이미지 3개 중 1개 Logitech UE MegaBoom Power Button Replacement, Outer Mesh: 1 단계, 이미지 3개 중 2개 Logitech UE MegaBoom Power Button Replacement, Outer Mesh: 1 단계, 이미지 3개 중 3개
      • Locate the ends of the speaker.
      • Put a plastic opening tool in-between the rubber end and the mesh.
      • Apply a upward force in order to pry open the end.
      • Apply this procedure to the other side as well.
      • Will take force.
      • Using metal tools may permanently mar your device.
      댓글 쓰기
    2. Logitech UE MegaBoom Power Button Replacement: 2 단계, 이미지 3개 중 1개 Logitech UE MegaBoom Power Button Replacement: 2 단계, 이미지 3개 중 2개 Logitech UE MegaBoom Power Button Replacement: 2 단계, 이미지 3개 중 3개
      • Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
      • You will hear clicks as it pries up, don't worry.
      • Remove all the rubber you pried off.
      댓글 쓰기
    3. Logitech UE MegaBoom Power Button Replacement: 3 단계, 이미지 2개 중 1개 Logitech UE MegaBoom Power Button Replacement: 3 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
      • Work the plastic retainer out of the channel all the way around the speaker.
      • Be gentle, it is easy to damage the fabric.
      • Repeat for other side.
      댓글 쓰기
    1. Logitech UE MegaBoom Power Button Replacement, Power Button: 4 단계, 이미지 2개 중 1개 Logitech UE MegaBoom Power Button Replacement, Power Button: 4 단계, 이미지 2개 중 2개
      • Locate the end of the speaker which contains the power button.
      • The circuit board which contains the power button should be visible.
      • Grasp the outer rim of this end cap and pull in an upward motion.
      • This might require some force.
      댓글 쓰기
    2. Logitech UE MegaBoom Power Button Replacement: 5 단계, 이미지 1개 중 1개
      • Insert a opening tool between the circuit board and one of the black clips which is holding the board in place.
      • Using the opening tool pry up on the clip allowing the board to be freed. Pry up on the second clip to fully release the board.
      • Using your fingers lift the board out of place.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Oscar Ambriz
회원 가입일: 09/27/17
978 평판
안내서 6개를 작성함
Cal Poly, Team S9-G2, Banghart Fall 2017 Cal Poly, Team S9-G2, Banghart Fall 2017 회원
CPSU-BANGHART-F17S9G2
4 회원들
안내서 24개를 작성함
3가이드 댓글
Will it still be waterproof after repairing?
TechBrush - 답글 공유
that would be a negative unless you really know what you are doing and can waterproof it
Justin Doubikin - 답글 공유
nice piece. i was able to follow the guide and got it right taking out the board. please where can one purchase the power button board. thanks
tony - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 12
지난 30일: 57
전체 시간: 5,462
