주요 콘텐츠로 건너뛰기
MSI MS-1782 Cooling Assembly Replacement
필요한 것
  1. MSI MS-1782 Cooling Assembly Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
    • Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
  2. MSI MS-1782 Cooling Assembly Replacement: 2 단계, 이미지 3개 중 1개 MSI MS-1782 Cooling Assembly Replacement: 2 단계, 이미지 3개 중 2개 MSI MS-1782 Cooling Assembly Replacement: 2 단계, 이미지 3개 중 3개
    • Use an iFixit opening pick to unclip the bottom cover.
    • It is ok to run the picks along the edges since there is nothing connected to the bottom cover. It is easier to start from the sides and then work your way forward.
    • After unclipping the bottom case, pull from the back of the laptop upwards using the lip of the bottom case as a handle.
  3. MSI MS-1782 Cooling Assembly Replacement, Cooling Assembly: 3 단계, 이미지 3개 중 1개 MSI MS-1782 Cooling Assembly Replacement, Cooling Assembly: 3 단계, 이미지 3개 중 2개 MSI MS-1782 Cooling Assembly Replacement, Cooling Assembly: 3 단계, 이미지 3개 중 3개
    • Loosen the captive screw on the left side of the left fan using a JIS #2 screwdriver.
    • Remove the 5.1 mm screw on the right side of the left fan using a JIS #2 screwdriver.
  4. MSI MS-1782 Cooling Assembly Replacement: 4 단계, 이미지 3개 중 1개 MSI MS-1782 Cooling Assembly Replacement: 4 단계, 이미지 3개 중 2개 MSI MS-1782 Cooling Assembly Replacement: 4 단계, 이미지 3개 중 3개
    • Gently detach the fan connector.
    • Remove the fan by lifting it out of its housing.
    • Be sure to handle the wire delicately; if not it will break.
  5. MSI MS-1782 Cooling Assembly Replacement: 5 단계, 이미지 3개 중 1개 MSI MS-1782 Cooling Assembly Replacement: 5 단계, 이미지 3개 중 2개 MSI MS-1782 Cooling Assembly Replacement: 5 단계, 이미지 3개 중 3개
    • Loosen the captive screw on the top of the right fan using a JIS #2 screwdriver.
    • Remove the 3.6 mm screw on the bottom of the right fan using a JIS #2 screwdriver.
  6. MSI MS-1782 Cooling Assembly Replacement: 6 단계, 이미지 3개 중 1개 MSI MS-1782 Cooling Assembly Replacement: 6 단계, 이미지 3개 중 2개 MSI MS-1782 Cooling Assembly Replacement: 6 단계, 이미지 3개 중 3개
  7. MSI MS-1782 Cooling Assembly Replacement: 7 단계, 이미지 3개 중 1개 MSI MS-1782 Cooling Assembly Replacement: 7 단계, 이미지 3개 중 2개 MSI MS-1782 Cooling Assembly Replacement: 7 단계, 이미지 3개 중 3개
    • Loosen the eight captive screws holding the heat sink in place using a JIS #2 screwdriver.
    • Be sure to follow the numbers that are next to the screws on the heatsink. This evenly removes pressure on the components when removing the heatsink.
  8. MSI MS-1782 Cooling Assembly Replacement: 8 단계, 이미지 3개 중 1개 MSI MS-1782 Cooling Assembly Replacement: 8 단계, 이미지 3개 중 2개 MSI MS-1782 Cooling Assembly Replacement: 8 단계, 이미지 3개 중 3개
    • Gently lift the heat sink and then pull forwards towards you.
결론
작성자
3다른 기여자 명과 함께
Joshua Pizzo
회원 가입일: 03/08/23
438 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 337
