주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
해당 분해도는 수리 안내서가 아닙니다. Mac mini (2024) 수리는 자사의 서비스 설명서를 사용하세요.
    1. Mac Mini (2024) Chip ID, Main Board Side 1: 1 단계, 이미지 2개 중 1개 Mac Mini (2024) Chip ID, Main Board Side 1: 1 단계, 이미지 2개 중 2개
      • Apple APL1206/339S01548 E M4 deca-core applications processor w/ GPU
      • Micron MT62F1G64D4AS-026 XT:C 8 GB LPDDR5 SDRAM Memory
      • Apple APL1066/343S00710 power management
      • Apple APL1067/343S00683 ? power management
      • Likely Apple U0P4F7-Y2 Thunderbolt 4 controller
      • Winbond W25Q64NE 8 MB serial NOR flash memory
      • Likely Infineon CYUSB2408 USB level shifter
      댓글 쓰기
    2. Mac Mini (2024) Chip ID, Main Board Side 1: 2 단계, 이미지 1개 중 1개
      • Winbond W25X40CL 4 Mb serial NOR flash memory
      • Texas Instruments TPS628502 2 A / adj. step-down converter
      • Analog Devices DC-DC converter
      • Texas Instruments TPS715A01 80 mA / adj. LDO regulator
      • Texas Instruments TPS2559 power distribution switch
      • Texas Instruments INA190A2 bidirectional current sense amplifier
      • Texas Instruments TLV7021 single comparator
      댓글 쓰기
    3. Mac Mini (2024) Chip ID: 3 단계, 이미지 2개 중 1개 Mac Mini (2024) Chip ID: 3 단계, 이미지 2개 중 2개
      • Likely Parade Technologies PS190 DisplayPort to HDMI converter
      • Genesys Logic GL3590-TBYS2 3 USB Type-C SuperSpeed+ & 3 USB Type-A SuperSpeed+ hub controller
      • Macronix MX25V2035FZUI 2 Mb serial NOR flash memory
      • Texas Instruments SN26A23 USB Type-C controller
      • GigaDevice GD25Q80E 1 MB serial NOR flash memory
      • Broadcom BCM57762 gigabit ethernet controller
      댓글 쓰기
    4. Mac Mini (2024) Chip ID: 4 단계, 이미지 1개 중 1개
      • Apple APL5791/343S00709 power management
      • Renesas multiphase controller
      • Cirrus Logic CS42L84A audio codec
      • Texas Instruments SN012776B0 audio amplifier
      • Texas Instruments TPS621371 step-down converter
      • Likely Renesas PWM DC-DC converter controller
      댓글 쓰기
    5. Mac Mini (2024) Chip ID: 5 단계, 이미지 1개 중 1개
      • onsemi NCP380LMU05AATBG power distribution switch
      • Likely Renesas mixed signal array
      • Texas Instruments TLV75801P 500 mA / adj. LDO regulator
      • Texas Instruments INA190A3 bidirectional current sense amplifier
      • Texas Instruments TLV7011 single comparator
      • Texas Instruments TLV9051 single operational amplifier
      댓글 쓰기
    6. Mac Mini (2024) Chip ID, Flash Module (NAND) Side 1: 6 단계, 이미지 2개 중 1개 Mac Mini (2024) Chip ID, Flash Module (NAND) Side 1: 6 단계, 이미지 2개 중 2개
      • SanDisk SDMVGKLK2 128G 128 GB NAND flash
      댓글 쓰기
    7. Mac Mini (2024) Chip ID, Flash Module (NAND) Side 2: 7 단계, 이미지 2개 중 1개 Mac Mini (2024) Chip ID, Flash Module (NAND) Side 2: 7 단계, 이미지 2개 중 2개
      • Apple 338S00600-A0 power management
      • Texas Instruments TPS62180 6 A synchronous buck converter
      댓글 쓰기
    8. Mac Mini (2024) Chip ID, Wireless Board: 8 단계, 이미지 2개 중 1개 Mac Mini (2024) Chip ID, Wireless Board: 8 단계, 이미지 2개 중 2개
      • Likely USI 339S01162 Bluetooth & WiFi module
      댓글 쓰기
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 72
지난 30일: 479
전체 시간: 16,432
