주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mac Mini Mid 2010 Fan Replacement
필요한 것
    1. Mac Mini Mid 2010 Fan Replacement, Bottom Cover: 1 단계, 이미지 2개 중 1개 Mac Mini Mid 2010 Fan Replacement, Bottom Cover: 1 단계, 이미지 2개 중 2개
      • Place your thumbs in the depressions cut into the bottom cover.
      • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
      댓글 쓰기
    2. Mac Mini Mid 2010 Fan Replacement: 2 단계, 이미지 1개 중 1개
      • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
      • Remove the bottom cover and set it aside.
      댓글 쓰기
    1. Mac Mini Mid 2010 Fan Replacement, Fan: 3 단계, 이미지 1개 중 1개
      • Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
      댓글 쓰기
    2. Mac Mini Mid 2010 Fan Replacement: 4 단계, 이미지 1개 중 1개
      • Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
      • If the fan doesn't separate from the standoff screw with a moderate amount of force, you can use a T6 Torx driver to simply remove this screw.
      댓글 쓰기
    3. Mac Mini Mid 2010 Fan Replacement: 5 단계, 이미지 1개 중 1개
      • Lift the fan out of the mini for enough clearance to access its connector.
      • Carefully pull the fan cables upward to lift the fan connector up out of its socket on the logic board.
      • Remove the fan.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 23명이 해당 안내서를 완성하였습니다.
2가이드 댓글
How do you know the order of the wires when placing the 4 wires back onto the motherboard?
Communications Department - 답글 공유
The connector is a snap in / snap out or more properly lift out connector. The connector goes back in only one way with the 4 pins aimed towards the wifi icon. To get it out you GENTLY lift the wires. I used my fingernail under the wires as they went from the fan into the connector.
Mike Stark - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 15
지난 30일: 67
전체 시간: 17,676
