주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mac Pro First Generation GPU Replacement
    1. Mac Pro First Generation GPU Replacement, Case Panel: 1 단계, 이미지 1개 중 1개
      • Lift the lever to unlock the case.
      댓글 쓰기
    2. Mac Pro First Generation GPU Replacement: 2 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      Anti-Static Wrist Strap
      $7.95
      • Remove the side panel of the Mac Pro.
      • Discharge any static electricity by touching a grounded surface prior to working on any internal components. Touching the metal PCI slot covers works great, or any other grounded metal surface. You can also wear a anti-static wrist strap.
      댓글 쓰기
    1. Mac Pro First Generation GPU Replacement, GPU (Graphics Card): 3 단계, 이미지 1개 중 1개
      • Locate the graphics card in the open panel side of your Mac Pro.
      댓글 쓰기
    2. Mac Pro First Generation GPU Replacement: 4 단계, 이미지 3개 중 1개 Mac Pro First Generation GPU Replacement: 4 단계, 이미지 3개 중 2개 Mac Pro First Generation GPU Replacement: 4 단계, 이미지 3개 중 3개
      • Unscrew the two thumb screws by twisting counterclockwise using your fingers until the slide lock is released.
      • Remove the slide lock.
      댓글 쓰기
    3. Mac Pro First Generation GPU Replacement: 5 단계, 이미지 3개 중 1개 Mac Pro First Generation GPU Replacement: 5 단계, 이미지 3개 중 2개 Mac Pro First Generation GPU Replacement: 5 단계, 이미지 3개 중 3개
      • Push up on the clip directly behind the graphics card to release it from its slot.
      • Slide the graphics card out of the slot using both hands by firmly holding the corners of the top of the card as shown.
      • Handle the card only by its edges. Don't touch any exposed components or connectors.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 23명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Andrew Kim
회원 가입일: 10/12/14
1,263 평판
안내서 3개를 작성함
Cal Poly, Team 6-24, Maness Fall 2014 Cal Poly, Team 6-24, Maness Fall 2014 회원
CPSU-MANESS-F14S6G24
4 회원들
안내서 25개를 작성함
8가이드 댓글
I have a first generation Mac Pro (1,1 – 2 x 3GHz Dual-Core Intel Xeon) that I purchased in November 2007.
I still love it.
THANK YOU for your valuable User Guides, and parts replacement guides!
David R Purnell - 답글 공유
Hi, I just installed Mac OS X High Sierra in my 2010 Mac Pro. The first monitor is active with the ATI Radeon HD5770. However the #2 screen is inactive with its ATI Radeon HD3870. Should I get another HD5770 or a different card so I can use the second screen?
Robert Lloyd - 답글 공유
For starters this is the first generation forum while your 2010 is a fifth generation model.
Nevertheless I had an interesting situation with the 5770 in a first gen machine that only ran under strange circumstances—a situation wroth sharing nevertheless.:
Ati Radeon X1900Xt had to be installed on bay 1 for the 5770 to work on bay 4
But for your situation, the question is: does the 3870 work standalone in its bay if the 5770 is taken out completely?
And if you swap the graphics cards into each others’ position, what’s the result?
allenwilson33 - 답글 공유
Hi. My 1st Gen Mac Pro is maxed out with OS X Lion 10.7. I heard I may be able to make it a 5th Gen by switching a chip. Is anyone familiar with this?
Harold L. Watkins - 답글 공유
Hi, I have a first generation MacBook Pro which is maxed out with OS X Lion 10.7. I heard I may be able to upgrade it to a generation 5 by switching out a chip. Is anyone familiar with this?
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 26
지난 30일: 96
전체 시간: 23,967
