주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mac Pro First Generation HDD Replacement
필요한 것
  1. Mac Pro First Generation HDD Replacement, HDD: 1 단계, 이미지 1개 중 1개
    • Open the Case Shut down your Mac Pro, give it a few minutes to cool off, and unplug all the wires and cables. Locate the latch on the back of the case and pull it out. The latch lifts out very easily and stops after an inch or two — do not try to force it any farther.
    댓글 쓰기
  2. Mac Pro First Generation HDD Replacement: 2 단계, 이미지 1개 중 1개
    • Opening this latch releases the side panel of your Mac Pro, which you should now be able to easily lift away from the case. Take it off and put it in a safe place
    댓글 쓰기
  3. Mac Pro First Generation HDD Replacement: 3 단계, 이미지 1개 중 1개
    • With the Mac Pro’s case now open, locate the four hard drive bays in the top half of the case.
    댓글 쓰기
  4. Mac Pro First Generation HDD Replacement: 4 단계, 이미지 1개 중 1개
    • Each bay has a number stamped on it, and they go in order from left to right. Bay #1 should contain the stock hard drive that was installed by Apple. Gently remove the bracket from the next empty hard drive bay — if you only purchased one hard drive with your computer, this should be bay it should easily slide out.
    댓글 쓰기
  5. Mac Pro First Generation HDD Replacement: 5 단계, 이미지 1개 중 1개
    • Remove your new hard drive from its packaging and use a phillips head screw drive to attach it to the bracket. Use the screws that are already included on the bracket.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 38명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Rico
회원 가입일: 02/20/13
963 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 53
전체 시간: 22,708
