주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mac Pro First Generation Hard Disk Drive (HDD) Replacement
필요한 것
    1. Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Case Panel: 1 단계, 이미지 1개 중 1개
      • Lift the lever to unlock the case.
      댓글 쓰기
    2. Mac Pro First Generation Hard Disk Drive (HDD) Replacement: 2 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      Anti-Static Wrist Strap
      $7.95
      • Remove the side panel of the Mac Pro.
      • Discharge any static electricity by touching a grounded surface prior to working on any internal components. Touching the metal PCI slot covers works great, or any other grounded metal surface. You can also wear a anti-static wrist strap.
      댓글 쓰기
    1. Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Locate the Hard Drive Bays: 3 단계, 이미지 1개 중 1개
      • Locate the desired hard drive bay after opening the case .
      • This is usually the drive closest to the front of the case.
      댓글 쓰기
    2. Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Remove the Hard Drive Bay: 4 단계, 이미지 3개 중 1개 Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Remove the Hard Drive Bay: 4 단계, 이미지 3개 중 2개 Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Remove the Hard Drive Bay: 4 단계, 이미지 3개 중 3개
      • Make sure that the clip used to release the side panel is open or the Hard Drive bays won't slide out
      • Pull the Hard Drive straight out by grabbing the metal sled from the bottom. It may be hard to pull out at first, but after it gets released the sled shouldn't take a lot of effort to remove.
      댓글 쓰기
    3. Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Remove metal Hard Drive sled: 5 단계, 이미지 3개 중 1개 Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Remove metal Hard Drive sled: 5 단계, 이미지 3개 중 2개 Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Remove metal Hard Drive sled: 5 단계, 이미지 3개 중 3개
      • When handling the hard drive hold it by the sled or sides be sure not to touch the green circuit board visible in all 3 pictures.
      • Locate the four 6-32 type screws on the Hard Drive sled.
      • Using a Phillips head screw driver remove the four screws and separate the metal sled from the Hard Drive
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Charlie Franklin
회원 가입일: 10/12/14
1,176 평판
안내서 1개를 작성함
Cal Poly, Team 6-24, Maness Fall 2014 Cal Poly, Team 6-24, Maness Fall 2014 회원
CPSU-MANESS-F14S6G24
4 회원들
안내서 25개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 41
지난 30일: 158
전체 시간: 26,627
