주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mac Pro First Generation Power Supply Unit Replacement
필요한 것
    1. Mac Pro First Generation Power Supply Unit Replacement, Case Panel: 1 단계, 이미지 1개 중 1개
      • Lift the lever to unlock the case.
      댓글 쓰기
    2. Mac Pro First Generation Power Supply Unit Replacement: 2 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      Anti-Static Wrist Strap
      $7.95
      • Remove the side panel of the Mac Pro.
      • Discharge any static electricity by touching a grounded surface prior to working on any internal components. Touching the metal PCI slot covers works great, or any other grounded metal surface. You can also wear a anti-static wrist strap.
      댓글 쓰기
    1. Mac Pro First Generation Power Supply Unit Replacement, Removing the Disk Drive: 3 단계, 이미지 3개 중 1개 Mac Pro First Generation Power Supply Unit Replacement, Removing the Disk Drive: 3 단계, 이미지 3개 중 2개 Mac Pro First Generation Power Supply Unit Replacement, Removing the Disk Drive: 3 단계, 이미지 3개 중 3개
      • The optical drive must be removed to access the power supply unit
      • Firmly grasp the handles of the shown compartment and pull out firmly to remove the optical drive bay.
      댓글 쓰기
    2. Mac Pro First Generation Power Supply Unit Replacement, Unplugging the Disk Drive: 4 단계, 이미지 2개 중 1개 Mac Pro First Generation Power Supply Unit Replacement, Unplugging the Disk Drive: 4 단계, 이미지 2개 중 2개
      • Firmly hold each of the two connectors and pull them out of their respective sockets.
      댓글 쓰기
    3. Mac Pro First Generation Power Supply Unit Replacement, Un-Mounting the Power Supply Unit: 5 단계, 이미지 2개 중 1개 Mac Pro First Generation Power Supply Unit Replacement, Un-Mounting the Power Supply Unit: 5 단계, 이미지 2개 중 2개
      • Remove the 4 marked 6-32 hex screws with a 2mm Phillips hex screwdriver.
      • There are a number of Phillips head screws underneath. These don't need to be removed to remove the power supply.
      • Note the different PSU for Mac Pro 1,1 through 3,1 versus Mac Pro 4,1 and 5,1.
      댓글 쓰기
    4. Mac Pro First Generation Power Supply Unit Replacement, Removing the Power Supply: 6 단계, 이미지 3개 중 1개 Mac Pro First Generation Power Supply Unit Replacement, Removing the Power Supply: 6 단계, 이미지 3개 중 2개 Mac Pro First Generation Power Supply Unit Replacement, Removing the Power Supply: 6 단계, 이미지 3개 중 3개
      • Be careful when pulling the power supply out, as it has several attached cables which don't have much slack.
      • Grip the handle on the left side of the power supply casing while gripping the right side of the power supply casing and pull upwards firmly to to take it out.
      댓글 쓰기
    5. Mac Pro First Generation Power Supply Unit Replacement, If power Supply only comes out a few Inches.: 7 단계, 이미지 2개 중 1개 Mac Pro First Generation Power Supply Unit Replacement, If power Supply only comes out a few Inches.: 7 단계, 이미지 2개 중 2개
      • For the Mac Pro (Early 2008/9), a.k.a. MacPro3,1 In the MacPro3,1, the power supply screws are 2.5mm hex, not T-10. Also, there is a cover plate behind the superdrive that has to be removed (2 phillips screws) to expose the power cable connections and those connectors must be detached and slid under fan before the power supply can be removed.
      댓글 쓰기
    6. Mac Pro First Generation Power Supply Unit Replacement, Disconnecting the Power Supply: 8 단계, 이미지 2개 중 1개 Mac Pro First Generation Power Supply Unit Replacement, Disconnecting the Power Supply: 8 단계, 이미지 2개 중 2개
      • Locate the four marked cables
      • Push down on the clip that is above each cable connector while firmly grasping each connector and pull each one back to remove each clip.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 79명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Eric Kuhta
회원 가입일: 10/12/14
1,241 평판
안내서 1개를 작성함
Cal Poly, Team 6-24, Maness Fall 2014 Cal Poly, Team 6-24, Maness Fall 2014 회원
CPSU-MANESS-F14S6G24
4 회원들
안내서 25개를 작성함
23가이드 댓글
15 min power on after off
Manish Kumar - 답글 공유
Hi
Very difficult to find the exact size of the bit for the screwdriver. And it is very tight to unscrew one of the screws.
Maybe I had spoiled the head of the screw.
What is the solution?
Thank you in advance.
Michel
Michel - 답글 공유
missing a very crucial step before step 6. if you don't remove the cover (where cd rom is) and unplug the PSU cable, you'll damage something.
for screws, 2.5mm didn't work for me, but i used a 3/32 hex with ball end, and at an angle, it will loosen screws.
Tino - 답글 공유
Doesn't work for a micron. Step 6 is impossible. Can't get the power supply out of its place more than a few centimeters. The side closest to the backplate of the casing can't come up only some millimeters, while also the fixed!! power cord is a serious obstruction.
Moreover there are nowhere cover plates left, so this is not a comparable situation as described in step 7.
Hugo Walg - 답글 공유
My last remark should be forgotten. The power cord has been connected to the Mac pro to give the impression that it's mounted fixedly to the power supply. But if you pull with very much force (an attempt of despair), it then again appears to be a 3-hole connector like is the case for common computers. If you don't know these systems, this is very treacherous.
Hugo Walg - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 62
지난 30일: 285
전체 시간: 89,366
