주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mac Pro First Generation RAM Replacement
    1. Mac Pro First Generation RAM Replacement, Case Panel: 1 단계, 이미지 1개 중 1개
      • Lift the lever to unlock the case.
      댓글 쓰기
    2. Mac Pro First Generation RAM Replacement: 2 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      Anti-Static Wrist Strap
      $7.95
      • Remove the side panel of the Mac Pro.
      • Discharge any static electricity by touching a grounded surface prior to working on any internal components. Touching the metal PCI slot covers works great, or any other grounded metal surface. You can also wear a anti-static wrist strap.
      댓글 쓰기
    1. Mac Pro First Generation RAM Replacement, RAM: 3 단계, 이미지 1개 중 1개
      • Locate the two RAM trays at the bottom of the Mac Pro.
      댓글 쓰기
    2. Mac Pro First Generation RAM Replacement: 4 단계, 이미지 2개 중 1개 Mac Pro First Generation RAM Replacement: 4 단계, 이미지 2개 중 2개
      • Pull the RAM tray out of the case by using both hands holding the edge of the ram board as shown.
      • Make sure you give enough time for the computer to cool down before you remove any internal hardware parts.
      댓글 쓰기
    3. Mac Pro First Generation RAM Replacement: 5 단계, 이미지 3개 중 1개 Mac Pro First Generation RAM Replacement: 5 단계, 이미지 3개 중 2개 Mac Pro First Generation RAM Replacement: 5 단계, 이미지 3개 중 3개
      • Push down on the ejectors on each side of a ram stick firmly and lift the RAM stick straight out carefully by holding each side.
      • To insert a new RAM stick, place the RAM into the slot with the correct orientation and push on the stick using both hands until the ejectors are clicked into place.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 22명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Andrew Kim
회원 가입일: 10/12/14
1,263 평판
안내서 3개를 작성함
Cal Poly, Team 6-24, Maness Fall 2014 Cal Poly, Team 6-24, Maness Fall 2014 회원
CPSU-MANESS-F14S6G24
4 회원들
안내서 25개를 작성함
2가이드 댓글
What is the name/or type of memory chip to use in the MacPro 2008.
Curtis - 답글 공유
Hi Curtis, hope you found the RAM type ok.
Basically server RAM, ECC, 667Mhz, FB always in Pairs.
Retired Apple, PC etc engineer.
coopernewlyn - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 68
전체 시간: 22,137
