주요 콘텐츠로 건너뛰기
Mac Studio 2023 Front USB-C Ports Replacement
필요한 것
  1. Mac Studio 2023 Front USB-C Ports Replacement, Prepare your Mac Studio for disassembly: 1 단계, 이미지 3개 중 1개 Mac Studio 2023 Front USB-C Ports Replacement, Prepare your Mac Studio for disassembly: 1 단계, 이미지 3개 중 2개 Mac Studio 2023 Front USB-C Ports Replacement, Prepare your Mac Studio for disassembly: 1 단계, 이미지 3개 중 3개
    • Completely shut down your Mac Studio.
    • Unplug all cables from your device.
  2. Mac Studio 2023 Front USB-C Ports Replacement, Flip your Mac Studio over: 2 단계, 이미지 1개 중 1개
    • Flip your Mac Studio over and lay it down so the bottom faces up and the SD card slot and two front USB‑C ports are facing you.
  3. Mac Studio 2023 Front USB-C Ports Replacement, Heat the bottom cover screw pad: 3 단계, 이미지 3개 중 1개 Mac Studio 2023 Front USB-C Ports Replacement, Heat the bottom cover screw pad: 3 단계, 이미지 3개 중 2개 Mac Studio 2023 Front USB-C Ports Replacement, Heat the bottom cover screw pad: 3 단계, 이미지 3개 중 3개
    • Adhesive strips secure the bottom cover screw pad.
    • Heat an iOpener and lay it over one of the bottom cover screws for two minutes to soften the adhesive near the screw—this is where you'll insert a spudger in the next step.
    • You can also use a hair dryer or heat gun, but be careful as extreme heat will warp the pad.
  4. Mac Studio 2023 Front USB-C Ports Replacement, Lift a section of bottom cover screw pad: 4 단계, 이미지 3개 중 1개 Mac Studio 2023 Front USB-C Ports Replacement, Lift a section of bottom cover screw pad: 4 단계, 이미지 3개 중 2개 Mac Studio 2023 Front USB-C Ports Replacement, Lift a section of bottom cover screw pad: 4 단계, 이미지 3개 중 3개
    • Insert the point of a spudger under the pad's inner edge, near the screw you applied heat to in the previous step.
    • This may take some force. If you're having trouble, apply more heat and try again.
    • Use the spudger to lift the pad and separate the adhesive.
  5. Mac Studio 2023 Front USB-C Ports Replacement, Separate the remaining adhesive: 5 단계, 이미지 3개 중 1개 Mac Studio 2023 Front USB-C Ports Replacement, Separate the remaining adhesive: 5 단계, 이미지 3개 중 2개 Mac Studio 2023 Front USB-C Ports Replacement, Separate the remaining adhesive: 5 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger under the pad.
    • Slide the spudger under the entire pad to separate the remaining adhesive.
  6. Mac Studio 2023 Front USB-C Ports Replacement, Remove the bottom cover screw pad: 6 단계, 이미지 1개 중 1개
    • Remove the bottom cover screw pad.
  7. Mac Studio 2023 Front USB-C Ports Replacement, Reassembly information: 7 단계, 이미지 3개 중 1개 Mac Studio 2023 Front USB-C Ports Replacement, Reassembly information: 7 단계, 이미지 3개 중 2개 Mac Studio 2023 Front USB-C Ports Replacement, Reassembly information: 7 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $2.99
    • During reassembly:
    • If the adhesive strips are still sticky, you can reuse them.
    • If you're applying new adhesive:
    • Use the flat end of a spudger and your fingers to scrape up and remove the old adhesive strips.
    • Use isopropyl alcohol and a microfiber cloth to remove the old adhesive residue.
    • If you don't have replacement adhesive, you can use strips of thin, double-sided tape 2–3 mm wide.
    • Apply the new adhesive strips to the bottom cover and remove their liners.
    • Firmly press the bottom cover screw pad into its recess to secure it.
  8. Mac Studio 2023 Front USB-C Ports Replacement, Remove the bottom cover screws: 8 단계, 이미지 2개 중 1개 Mac Studio 2023 Front USB-C Ports Replacement, Remove the bottom cover screws: 8 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    FixMat
    $31.41
    • While the Mac Studio uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a T10 Torx screwdriver to remove the four 8 mm‑long screws securing the bottom cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came.
  9. Mac Studio 2023 Front USB-C Ports Replacement, Remove the bottom cover: 9 단계, 이미지 3개 중 1개 Mac Studio 2023 Front USB-C Ports Replacement, Remove the bottom cover: 9 단계, 이미지 3개 중 2개 Mac Studio 2023 Front USB-C Ports Replacement, Remove the bottom cover: 9 단계, 이미지 3개 중 3개
    • Insert the point of a spudger in one of the bottom cover's ventilation holes and lift the cover until you can grab it with your fingers.
    • Remove the bottom cover.
    • To orient the bottom cover, align the Kensington lock cutout in the top left corner with the corresponding one on the internal frame.
  10. Mac Studio 2023 Front USB-C Ports Replacement, Remove the power supply screws: 10 단계, 이미지 2개 중 1개 Mac Studio 2023 Front USB-C Ports Replacement, Remove the power supply screws: 10 단계, 이미지 2개 중 2개
    • Use a T10 Torx screwdriver to remove the six screws securing the power supply:
    • Four 6 mm‑long screws
    • Two 7 mm‑long screws with washers
    • You may need to remove a sticker to access these screws. If you do, save it for reassembly.
  11. Mac Studio 2023 Front USB-C Ports Replacement, Reposition your Mac Studio: 11 단계, 이미지 1개 중 1개
    • Flip your Mac Studio around so the rear ports are facing you.
  12. Mac Studio 2023 Front USB-C Ports Replacement, Disconnect the power cord port cable: 12 단계, 이미지 3개 중 1개 Mac Studio 2023 Front USB-C Ports Replacement, Disconnect the power cord port cable: 12 단계, 이미지 3개 중 2개 Mac Studio 2023 Front USB-C Ports Replacement, Disconnect the power cord port cable: 12 단계, 이미지 3개 중 3개
    • A tight plastic latch secures the power cord port cable.
    • Firmly hold the power supply with one hand and lift up the edge near the power cord port.
    • With your free hand, pinch the head of the power cord port connector to unclip it and pull straight down to disconnect the cable.
  13. Mac Studio 2023 Front USB-C Ports Replacement, Tilt up the power supply: 13 단계, 이미지 1개 중 1개
    • Only grab the power supply by its edges. Various power components and capacitors are left exposed.
    • Carefully tilt the power supply away from the power cord port so it's at a 90-degree angle.
    • Be careful not to strain the cable that's still connected to the power supply.
    • Keep the power supply tilted up for the next step.
  14. Mac Studio 2023 Front USB-C Ports Replacement, Disconnect the power supply signal cable: 14 단계, 이미지 3개 중 1개 Mac Studio 2023 Front USB-C Ports Replacement, Disconnect the power supply signal cable: 14 단계, 이미지 3개 중 2개 Mac Studio 2023 Front USB-C Ports Replacement, Disconnect the power supply signal cable: 14 단계, 이미지 3개 중 3개
    • A delicate plastic clip secures the power supply signal cable.
    • With your free hand, pinch the head of the power supply connector to unclip it and pull straight away from the socket to disconnect the cable.
  15. Mac Studio 2023 Front USB-C Ports Replacement, Remove the power supply: 15 단계, 이미지 1개 중 1개
    • Remove the power supply.
  16. Mac Studio 2023 Front USB-C Ports Replacement, Reposition your Mac Studio: 16 단계, 이미지 1개 중 1개
    • Flip your Mac Studio around so the SD card reader and two front USB‑C ports are facing you.
  17. Mac Studio 2023 Front USB-C Ports Replacement, Remove the internal frame screws: 17 단계, 이미지 2개 중 1개 Mac Studio 2023 Front USB-C Ports Replacement, Remove the internal frame screws: 17 단계, 이미지 2개 중 2개
    • Use a T6 Torx screwdriver to remove the eight screws securing the internal frame:
    • Seven 5 mm‑long screws
    • One 4 mm‑long screw
  18. Mac Studio 2023 Front USB-C Ports Replacement, Remove the internal frame: 18 단계, 이미지 2개 중 1개 Mac Studio 2023 Front USB-C Ports Replacement, Remove the internal frame: 18 단계, 이미지 2개 중 2개
  19. Mac Studio 2023 Front USB-C Ports Replacement, Reposition your Mac Studio: 19 단계, 이미지 1개 중 1개
  20. Mac Studio 2023 Front USB-C Ports Replacement, Remove the USB‑C bracket: 20 단계, 이미지 3개 중 1개 Mac Studio 2023 Front USB-C Ports Replacement, Remove the USB‑C bracket: 20 단계, 이미지 3개 중 2개 Mac Studio 2023 Front USB-C Ports Replacement, Remove the USB‑C bracket: 20 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Flexible Extension
    $6.99
  21. Mac Studio 2023 Front USB-C Ports Replacement, Remove the cable cover: 21 단계, 이미지 3개 중 1개 Mac Studio 2023 Front USB-C Ports Replacement, Remove the cable cover: 21 단계, 이미지 3개 중 2개 Mac Studio 2023 Front USB-C Ports Replacement, Remove the cable cover: 21 단계, 이미지 3개 중 3개
    • Use a T3 Torx screwdriver to remove the two 2 mm‑long screws securing the USB‑C port cable cover.
    • Use tweezers or your fingers to remove the cover.
  22. Mac Studio 2023 Front USB-C Ports Replacement, Disconnect the USB-C ports: 22 단계, 이미지 2개 중 1개 Mac Studio 2023 Front USB-C Ports Replacement, Disconnect the USB-C ports: 22 단계, 이미지 2개 중 2개
    • Be very careful not to scrape off or damage any surface mounted components during this step.
    • Use the point of a spudger to pry up and disconnect the USB‑C port press connector from the logic board.
    • To reconnect press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  23. Mac Studio 2023 Front USB-C Ports Replacement, Reposition your Mac Studio: 23 단계, 이미지 1개 중 1개
    • Carefully stand up your Mac Studio so the rear ports face up.
  24. Mac Studio 2023 Front USB-C Ports Replacement, Remove the USB-C ports screws: 24 단계, 이미지 3개 중 1개 Mac Studio 2023 Front USB-C Ports Replacement, Remove the USB-C ports screws: 24 단계, 이미지 3개 중 2개 Mac Studio 2023 Front USB-C Ports Replacement, Remove the USB-C ports screws: 24 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Flexible Extension
    $6.99
    • Use a T5 Torx screwdriver to remove the two 5 mm‑long screws securing the USB-C ports.
    • These screws may be hard to access. If you can't insert your screwdriver properly, use a flexible extension to avoid stripping screws or damaging the logic board.
    • Partially tighten the two screws securing the top of the ports.
    • Put the USB-C bracket into place and partially tighten the screw that secures it.
    • Lay your Mac Studio down and plug a cable into each port to ensure proper fit and alignment, adjusting the ports as necessary—the cables should be easy to insert and remove.
    • With both cables plugged in and the ports in position, fully tighten all three screws.
    • Unplug any cables before continuing reassembly.
  25. Mac Studio 2023 Front USB-C Ports Replacement, Remove the USB-C ports: 25 단계, 이미지 3개 중 1개 Mac Studio 2023 Front USB-C Ports Replacement, Remove the USB-C ports: 25 단계, 이미지 3개 중 2개 Mac Studio 2023 Front USB-C Ports Replacement, Remove the USB-C ports: 25 단계, 이미지 3개 중 3개
    • Use your fingers to lift the ports out of their recesses and remove them.
    • Don't try to remove an individual port. A flex cable connects them and can easily be damaged.
    • During reassembly, put the ports into their recesses, making sure the press connector stays above the logic board.
결론
작성자
1다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
149,209 평판
안내서 995개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,608개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 7
지난 30일: 30
전체 시간: 574
