주요 콘텐츠로 건너뛰기
MacBook Air 11" Mid 2011 Battery Replacement
필요한 것
  1. MacBook Air 11" Mid 2011 Battery Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Mid 2011 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Mid 2011 Battery Replacement, Battery: 3 단계, 이미지 2개 중 1개 MacBook Air 11" Mid 2011 Battery Replacement, Battery: 3 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
  4. MacBook Air 11" Mid 2011 Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the following five screws securing the battery to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
  5. MacBook Air 11" Mid 2011 Battery Replacement: 5 단계, 이미지 1개 중 1개
    • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
결론
다른 309명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Walter Galan
706,151 평판
안내서 1,203개를 작성함
59가이드 댓글
Arrived with 52% charge, capacity 4593 mAh of 4680 mAh. 98% health, manufacture date of the iFixit replacement battery is Feb 4 2012 (2.9 years), with 0 charge cycles. My order arrived extremely fast, and replacing the battery itself was easier than expected. Overall speed of my MBA seems to have improved somewhat as well. Despite my MBA mid-11 being almost 3.5 years old, the internals, fan included, were all fairly free from dust. So far, so good.
andreaspall - 답글
I removed a battery pack from a mid-2011 MBA. Two of the lithium polymer cells had expanded so much that the upper case was bulging out about 0.5cm. The bulge un-bulged itself as soon as I loosened the screws on the lower case. There doesn't seem to be any significant damage to the hardware. Pretty wild. Also, despite this repair being listed as "Difficulty: Moderate", it's about the easiest thing you can do that involves opening the bottom cover.
Joey - 답글
THIS IS FANTASTIC!! I ordered it on a Thursday & received it on a Saturday! Came very protected in the box. It took me only 40 min to replace the battery & these instructions were excellent to follow! I highly recommend!
tiffmariepaul - 답글
Very easy, and I normally have little patience for this sort of task. Took me about 20 minutes. Replacement battery was 90% charged and has 101% (!?) health.
craig - 답글
I would like to agree: the difficulty is even less than easy
Leona Eden - 답글
댓글 쓰기
조회 통계:
지난 24시간: 25
지난 7일: 217
지난 30일: 820
전체 시간: 244,144
