주요 콘텐츠로 건너뛰기
MacBook Air Models A1237 and A1304 AirPort/Bluetooth Bracket Replacement
필요한 것
  1. MacBook Air Models A1237 and A1304 AirPort/Bluetooth Bracket Replacement, Lower Case: 1 단계, 이미지 1/1
    • Unplug your MacBook Air and power it off before you proceed.
    • Remove ten Phillips screws securing the lower case to the MacBook Air:
    • Six 2.8 mm screws
    • Two 3.8 mm screws
    • Two 5.4 mm screws
  2. MacBook Air Models A1237 and A1304 AirPort/Bluetooth Bracket Replacement: 2 단계, 이미지 1/2 MacBook Air Models A1237 and A1304 AirPort/Bluetooth Bracket Replacement: 2 단계, 이미지 2/2
    • Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
  3. MacBook Air Models A1237 and A1304 AirPort/Bluetooth Bracket Replacement, Battery: 3 단계, 이미지 1/1
    • Disconnect the battery connector by pulling it straight out of its socket.
  4. MacBook Air Models A1237 and A1304 AirPort/Bluetooth Bracket Replacement: 4 단계, 이미지 1/1
    • Remove the following nine screws securing the battery to the Air:
    • Four 2.9 mm Phillips.
    • Four 3.8 mm Phillips.
    • One 7.2 mm Phillips.
  5. MacBook Air Models A1237 and A1304 AirPort/Bluetooth Bracket Replacement: 5 단계, 이미지 1/1
    • Lift the battery out of the Air.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  6. MacBook Air Models A1237 and A1304 AirPort/Bluetooth Bracket Replacement, AirPort/Bluetooth Bracket: 6 단계, 이미지 1/1
    • Remove the two Phillips screws securing the AirPort/Bluetooth bracket to the upper case.
  7. MacBook Air Models A1237 and A1304 AirPort/Bluetooth Bracket Replacement: 7 단계, 이미지 1/1
    • Lift the AirPort/Bluetooth bracket out of the upper case.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Walter Galan
694,692 평판
안내서 1,203개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 11,574
