주요 콘텐츠로 건너뛰기
MacBook Air Models A1237 and A1304 Battery Replacement
필요한 것
동영상 개요
  1. MacBook Air Models A1237 and A1304 Battery Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    • Unplug your MacBook Air and power it off before you proceed.
    • Remove ten Phillips screws securing the lower case to the MacBook Air:
    • Six 2.8 mm screws
    • Two 3.8 mm screws
    • Two 5.4 mm screws
  2. MacBook Air Models A1237 and A1304 Battery Replacement: 2 단계, 이미지 2개 중 1개 MacBook Air Models A1237 and A1304 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
  3. MacBook Air Models A1237 and A1304 Battery Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Disconnect the battery connector by pulling it straight out of its socket.
  4. MacBook Air Models A1237 and A1304 Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the following nine screws securing the battery to the Air:
    • Four 2.9 mm Phillips.
    • Four 3.8 mm Phillips.
    • One 7.2 mm Phillips.
  5. MacBook Air Models A1237 and A1304 Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the battery out of the Air.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
결론
다른 118명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Walter Galan
706,213 평판
안내서 1,203개를 작성함
12가이드 댓글
This doesn't make sense. The battery cost $110, plus shipping, which will come out to about $130, with next day shipping. Apple does it for $129, and will do it same day with an appointment. I know some people will do it for fun, but if you're trying to save money, I have to roll with Apple on this one.
http://www.apple.com/support/macbookair/...
jeehtoven - 답글
I ordered a replacement battery for $75 (shipping included) and 3 days later the switch is done (thanks for this easy guide!). Now, my wife's MBA is free from power cord again! It is a no brainer!
Mathieu Brassard - 답글
I have bought the This replacment a1245 battey - A1237 and A1304 Battery
thanks for the install guide
BatteryJohn - 답글
The host is cute.
tonkatuph - 답글
Well, that was easy. Now I can us my macbook air again without wires.
ppatel - 답글
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 32
지난 30일: 173
전체 시간: 235,205
