주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
MacBook Core 2 Duo Fan Replacement
필요한 것
    1. MacBook Core 2 Duo Fan Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
      댓글 쓰기
    2. MacBook Core 2 Duo Fan Replacement: 2 단계, 이미지 1개 중 1개
      • Lift the battery out of the computer.
      댓글 쓰기
    1. MacBook Core 2 Duo Fan Replacement, Memory Cover: 3 단계, 이미지 1개 중 1개
      • Unscrew the three evenly-spaced Phillips 000 screws from along the rear wall of the battery compartment.
      • The screws are captive to the metal memory cover so you cannot lose them.
      • Using The Flexible Extension sold by iFixit will help with this step.
      댓글 쓰기
    2. MacBook Core 2 Duo Fan Replacement: 4 단계, 이미지 1개 중 1개
      • Grasp the right end of the L-shaped memory cover, then pull it towards you so it clears the battery compartment opening.
      • Lift the memory cover up and out of the computer.
      댓글 쓰기
    1. MacBook Core 2 Duo Fan Replacement, Upper Case: 5 단계, 이미지 1개 중 1개
      • Remove the following 3 screws:
      • One 11 mm Phillips#00 in the middle of the lower case. (Head: 5mm dia. x .75mm thick)
      • Two 14.5 mm Phillips #00 (Head: 5mm dia. x .75mm thick)
      • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
      • The shorter of the three screws goes in the middle of the lower case.
      댓글 쓰기
    2. MacBook Core 2 Duo Fan Replacement: 6 단계, 이미지 1개 중 1개
      • Take extra caution with these screws as they can strip easily!
      • You could use a flexible extension to minimize stripping.
      • Remove the following 3 screws from the rear wall of the battery compartment:
      • One 3 mm Phillips #0. (Head: 2.75 mm. dia.)
      • Two 4 mm Phillips #0 on the either side. (Head: 2.75mm dia.)
      댓글 쓰기
    3. MacBook Core 2 Duo Fan Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the two Phillips screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
      • Two 6.25 mm Phillips #000. (Head: 4 mm. dia. x .5mm thick)
      댓글 쓰기
    4. MacBook Core 2 Duo Fan Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the four indicated Phillips screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screws.
      • Four 3.25 mm Phillips #000. (Head: 4 mm. dia. x 4mm thick)
      댓글 쓰기
    5. MacBook Core 2 Duo Fan Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the following 4 screws from the back of the computer:
      • Two 11 mm Phillips #00, with Shank (2.2mm dia. x 2 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
      • Two 7.25 mm Phillips #00, with Shank (2mm dia. x 3.75 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
      • During reassembly, the two longer screws go on the inside, and the two shorter screws go on the outside.
      댓글 쓰기
    6. MacBook Core 2 Duo Fan Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the two Phillips screws from the optical drive (right) side of the computer:
      • Two 5.2 mm Phillips #00, with shank (2.3mm dia. x 3.25 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
      • It is not necessary to remove the similar screws on the ports (left) side of the computer.
      댓글 쓰기
    7. MacBook Core 2 Duo Fan Replacement: 11 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      Plastic Cards
      $2.99
      • There's a trackpad and keyboard ribbon cable connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
      • Use a plastic opening tool, an expired plastic credit, or a similarly-thick card to pry up on the upper case, starting in the upper-left corner and working around to the front of the computer.
      • The upper case is likely to stick at its connection above the front edge of the optical drive. If this happens, first free all other sides, then proceed to pull upward on the upper case from either side of the optical drive opening. Here again, inserting a plastic card, guitar pick, etc. can be useful.
      • If you stand the base of the MacBook on one end to get a better look, you may displace the four grey plastic clips that hold the right side of the upper case in place. Don't panic. They slide into slots at the top rightmost edge of the lower frame, above the front edge of the optical drive.
      • During reassembly, make sure the clips on the right side, above the optical drive, click firmly into place. They're different from the clips on the left side, and so normally they require a little firmer pressure to click into place.
      댓글 쓰기
    8. MacBook Core 2 Duo Fan Replacement: 12 단계, 이미지 3개 중 1개 MacBook Core 2 Duo Fan Replacement: 12 단계, 이미지 3개 중 2개 MacBook Core 2 Duo Fan Replacement: 12 단계, 이미지 3개 중 3개
      • While holding up the upper case, pull up the black tab on the connector end of the silver ribbon cable away from the connector's socket on the logic board.
      • If there is no black tab, you can also use a spudger to gently pry the connector out of its socket on the logic board. This connector is tall, so be sure to pry straight up.
      • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
      • While you have the upper case removed, it's a good time to remove dust, hair, etc. It's best to use a can of compressed air, though if you use a brush, make sure that its bristles are made of a material (usually animal hair) that doesn't generate static electricity, which can destroy electronics.
      • Upon reassembly, there are 4 grey plastic clips installed in slots running along the top of the frame in front of the optical drive (refer to second and third pictures). These clips must be installed in their slots for their mating tabs on the underside of the right side of the upper case to snap into them.
      댓글 쓰기
    1. MacBook Core 2 Duo Fan Replacement, Fan: 13 단계, 이미지 1개 중 1개
      • Use a spudger to disconnect the orange optical drive cable from the logic board.
      댓글 쓰기
    2. MacBook Core 2 Duo Fan Replacement: 14 단계, 이미지 2개 중 1개 MacBook Core 2 Duo Fan Replacement: 14 단계, 이미지 2개 중 2개
      • Use a spudger to disconnect the black fan connector from the logic board.
      • If you have a MacBook Core 2 Duo Santa Rosa/Penryn, the black fan connector resides in a different location.
      댓글 쓰기
    3. MacBook Core 2 Duo Fan Replacement: 15 단계, 이미지 1개 중 1개
      • Deroute the fan cable from behind the tab on the left side of the fan.
      댓글 쓰기
    4. MacBook Core 2 Duo Fan Replacement: 16 단계, 이미지 1개 중 1개
      • Peel up the silver foil tape between the fan and the optical drive.
      댓글 쓰기
    5. MacBook Core 2 Duo Fan Replacement: 17 단계, 이미지 1개 중 1개
      • Use a spudger to move the gray display data and black speaker cables to the right. This will reveal a silver screw securing the fan housing to the lower case.
      댓글 쓰기
    6. MacBook Core 2 Duo Fan Replacement: 18 단계, 이미지 1개 중 1개
      • Remove the following 2 screws:
      • One 3 mm Phillips on the right side of the fan.
      • One 6 mm Phillips on the left side of the fan.
      댓글 쓰기
    7. MacBook Core 2 Duo Fan Replacement: 19 단계, 이미지 1개 중 1개
      • Lift the fan and its attached mounting bracket up and out of the computer, being careful not to rip the black felt tape.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 308명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개를 작성함
23가이드 댓글
My wife's MacBook has been overheating for some time, and then shutting itself down. Your instructions were great, but I did note that I needed to unscrew the cable tie near the speaker in Step 17.
The system had some dust in it, used the air can to spray it all out. Dust was on the heatsink vents, too. Closed it all up, and peak temps during a software install that crashed it three times yesterday was 145F - yesterday it was passing 170F and crashing.
Thanks for the instructions, ifixit!
Redwolf - 답글 공유
Download and print out the PDF version of the repair guide. Tape the screws to their corresponding image in the guide so that you can't go wrong!
Donal Caulfield - 답글 공유
what a great idea! i've been thinking about a solution for organizing screws. that's genius!
Victoria - 답글 공유
Good Idea. I generally sketch up rough diagrams and putsmall pieces of double sided tapes and stick the screws on my drawing.
Sandeep Giri - 답글 공유
Worked a treat!!
aweinmann - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 20
지난 30일: 102
전체 시간: 302,891
