소개
使用本指南来移除MacBook Pro 的粘合电池。 推荐使用iFixit 更换套件。 您的套件中的液体粘合剂去除剂将溶解固定电池的粘合剂,从而轻松拆卸电池。 或者,您可以使用iOpener,以便在撬出电池之前软化粘合剂。
“iFixit胶粘剂去除剂是极度易燃的。”在通风良好的地方进行。 在此过程中,请不要吸烟或者在明火附近工作。
'''“为了安全起见,在开始执行此程序之前请先用尽MacBook Pro的电池。” 如果意外穿刺充电的锂离子电池可能会造成危险且无法控制的火灾。如果你的电池膨胀鼓包了,请采取额外措施。
注意':用于溶解电池胶粘剂的溶剂可能会损坏某些塑料部件,如MacBook Pro的塑料扬声器外壳。 使用溶剂时要小心。
如果你在使用注射器和瓶子分装的旧款iFixit胶水去除剂,click here for a slightly modified set of instructions.
필요한 것
要重新组装你的设备,请按照本指南的相反顺序进行操作。
다른 241명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 49개
What is the part number for the mid 2014 13 inch MacBook Pro battery? I see a lot of batteries for sale for the mid 2013 online. Are they compatible?
MacBook Pro 13" Retina (Late 2013-Mid 2014) Battery here is a battery replacement.
Macbook Pro A1502 not charging after disassembly/assembly (I just wanted to clean the touchpad). MagSafe is orange but the Macbook is not charging - running only when plugged in. MacOS says the battery needs to be replaced - even if it has 82% charged.. I alson tried reset of SMC and PRAM with no effect..
Any advice? Thanks
Same problem here. Did you find a solution?
Tim Bo -
