이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계에 사용된 도구:Magnetic Project Mat$19.95
하단 케이스를 상단 케이스에 고정하는 다음 나사 열 개를 풀어주세요:
2.3mm P5 Pentalobe/펜타로브/별나사 두 개
3.0mm P5 Pentalobe/펜타로브/별나사 여덟 개
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the following screws securing the heat sink to the logic board assembly:
One 2.4 mm Phillips #00 screw
One 3.4 mm T5 Torx screw
Four 2.7 mm T5 Torx screws
Use the flat end of a spudger to pry the right side of the I/O board data cable connector up off its socket on the I/O board.
Wedge the flat end of a spudger beneath the left side of the I/O board data cable connector.
Gently twist the spudger to disconnect the I/O board data cable connector from its socket on the logic board.
Use the tip of a spudger to push the iSight camera cable connector straight away from its socket on the logic board.
Use the tip of a spudger to flip up the retaining flap on the right fan ribbon cable ZIF socket.
Pull the right fan ribbon cable straight out of its socket on the logic board.
Remove the three 3.1 mm T5 Torx screws securing the right fan to the logic board assembly.
다른 7명이 해당 안내서를 완성하였습니다.
