주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement
필요한 것
  1. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    댓글 쓰기
  2. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: 2 단계, 이미지 1개 중 1개
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
    댓글 쓰기
  3. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: 3 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: 3 단계, 이미지 2개 중 2개
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    댓글 쓰기
  4. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement, Battery Connector: 4 단계, 이미지 1개 중 1개
    • If necessary, remove the plastic cover adhered to the battery contact board.
    댓글 쓰기
  5. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: 5 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: 5 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
    댓글 쓰기
  6. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: 6 단계, 이미지 1개 중 1개
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
    댓글 쓰기
  7. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement, MagSafe DC-In Board: 7 단계, 이미지 3개 중 1개 MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement, MagSafe DC-In Board: 7 단계, 이미지 3개 중 2개 MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement, MagSafe DC-In Board: 7 단계, 이미지 3개 중 3개
    • Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board.
    • Pull in the direction of the cable, parallel to the logic board. Do not pull up.
    댓글 쓰기
  8. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: 8 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: 8 단계, 이미지 2개 중 2개
    • Pull the DC-In board connector straight out of its socket on the logic board.
    댓글 쓰기
  9. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the two 3.5 mm T5 Torx screws securing the MagSafe DC-In board to the upper case.
    • You may need to gently push the display cable out of the way to expose the screws.
    댓글 쓰기
  10. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: 10 단계, 이미지 3개 중 1개 MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: 10 단계, 이미지 3개 중 2개 MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: 10 단계, 이미지 3개 중 3개
    • Use the MagSafe DC-In board cable to pull the board out and up from the upper case to remove it.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 30명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Sam Goldheart
회원 가입일: 10/18/12
477,626 평판
안내서 538개를 작성함
iFixit iFixit 회원
Staff
122 회원들
안내서 26,617개를 작성함
7가이드 댓글
Thanks very much, took me 10 mins, A nice cheap and fast repair for my damaged MagSafe socket
lewismacqueen - 답글 공유
Thank you for your guidance! Spent $30 on tools as opposed to hundreds and made a simple repair
Brian Smithson - 답글 공유
Thank you ...just what we need !..
Mark White - 답글 공유
Did anyone else lose the display to their MacBook Pro mid 2014 after following this repair?
Vance - 답글 공유
yes I just did and wonder what you did to solve this?
Kaleem - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 16
지난 30일: 83
전체 시간: 18,874
