주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement
필요한 것
    1. MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement, Remove the lower case screws: 1 단계, 이미지 1개 중 1개
      • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
      • Seven 3 mm Phillips screws.
      댓글 쓰기
    2. MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement, Lift the lower case away: 2 단계, 이미지 1개 중 1개
      • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
      댓글 쓰기
    1. MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement, Fan: 3 단계, 이미지 3개 중 1개 MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement, Fan: 3 단계, 이미지 3개 중 2개 MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement, Fan: 3 단계, 이미지 3개 중 3개
      • Use a spudger to pry up the fan connector out of its socket on the logic board.
      • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
      • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
      댓글 쓰기
    2. MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the following three screws:
      • One 7 mm T6 Torx screw
      • Two 5.4 mm T6 Torx screws
      댓글 쓰기
    3. MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 5 단계, 이미지 1개 중 1개
      • Lift the fan out of the upper case.
      댓글 쓰기
    1. MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement, Logic Board: 6 단계, 이미지 3개 중 1개 MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement, Logic Board: 6 단계, 이미지 3개 중 2개 MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement, Logic Board: 6 단계, 이미지 3개 중 3개
      • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
      • Gently pull the display data cable connector away parallel to the board.
      • Do not pull the connector upwards, or you may damage the connector.
      댓글 쓰기
    2. MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 7 단계, 이미지 2개 중 1개 MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 7 단계, 이미지 2개 중 2개
      • Remove the following two screws securing the display data cable bracket to the upper case:
      • One 8.6 mm Phillips
      • One 5.6 mm Phillips
      • Lift the display data cable bracket out of the upper case.
      댓글 쓰기
    3. MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 8 단계, 이미지 1개 중 1개
      • Use the flat end of a spudger to pry the subwoofer and right speaker connector up off the logic board.
      댓글 쓰기
    4. MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 9 단계, 이미지 1개 중 1개
      • Pull the camera cable connector toward the optical drive to disconnect it from the logic board.
      • This socket is metal and can be easily bent. Be sure to align the connector with its socket on the logic board before mating the two pieces.
      댓글 쓰기
    5. MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 10 단계, 이미지 3개 중 1개 MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 10 단계, 이미지 3개 중 2개 MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 10 단계, 이미지 3개 중 3개
      • Use the flat end of a spudger to pry the optical drive, hard drive, and trackpad cable connectors up off the logic board.
      댓글 쓰기
    6. MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 11 단계, 이미지 3개 중 1개 MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 11 단계, 이미지 3개 중 2개 MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 11 단계, 이미지 3개 중 3개
      • Use your fingernail or the tip of a spudger to flip up the cable retaining flap on the ZIF socket for the keyboard ribbon cable.
      • Use your spudger to slide the keyboard ribbon cable out of its socket.
      댓글 쓰기
    7. MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 12 단계, 이미지 1개 중 1개
      • Peel the small strip of black tape off the keyboard backlight ribbon cable socket.
      댓글 쓰기
    8. MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 13 단계, 이미지 3개 중 1개 MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 13 단계, 이미지 3개 중 2개 MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 13 단계, 이미지 3개 중 3개
      • Use the tip of a spudger to flip up the cable retaining flap on the ZIF socket for the keyboard backlight ribbon cable.
      • Use your spudger to slide the keyboard backlight ribbon cable out of its socket.
      댓글 쓰기
    9. MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 14 단계, 이미지 1개 중 1개
      • Use the flat end of a spudger to pry the battery indicator cable connector up off the logic board.
      댓글 쓰기
    10. MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 15 단계, 이미지 1개 중 1개
      • Use the tip of a spudger to pry the microphone off the adhesive attaching it to the upper case.
      댓글 쓰기
    11. MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 16 단계, 이미지 1개 중 1개
      • Remove the following screws:
      • Two 7 mm T6 Torx screws from the DC-In board
      • Five 3.3 mm T6 Torx screws
      • Two 4 mm T6 Torx screws
      댓글 쓰기
    12. MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 17 단계, 이미지 2개 중 1개 MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 17 단계, 이미지 2개 중 2개
      • Removing the battery before lifting out the logic board is not strictly required, but makes removing the logic board easier and safer. If you leave your battery in, be especially careful not to bend the logic board against the battery's case near its bar code.
      • Remove the following Tri-point screws securing the battery to the upper case:
      • One 5.5 mm Tri-point screw
      • One 13.5 mm Tri-point screw
      • Lift the battery out of the upper case.
      댓글 쓰기
    13. MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 18 단계, 이미지 2개 중 1개 MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 18 단계, 이미지 2개 중 2개
      • Lift the logic board from its left edge and raise it until the ports clear the side of the upper case.
      • Pull the logic board away from the side of the upper case and remove it, minding the DC-In board that may get caught.
      댓글 쓰기
    1. MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement, Optical Drive: 19 단계, 이미지 1개 중 1개
      • For precautionary purposes, we advise that you disconnect the subwoofer connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
      • Remove the soft padding that may be on top and gently pull the connector up out of its socket on the logic board.
      댓글 쓰기
    2. MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 20 단계, 이미지 1개 중 1개
      • It will be necessary to slide the small clear plastic cable retainer (boxed in red) glued to the logic board out of the way before disconnecting the camera cable. Be careful not to break any components off the board as you slide it away from the camera cable connector.
      댓글 쓰기
    3. MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 21 단계, 이미지 1개 중 1개
      • Use the flat end of a spudger to pry the optical drive connector straight up off the logic board.
      댓글 쓰기
    4. MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 22 단계, 이미지 1개 중 1개
      • Use the flat end of a spudger to pry the hard drive connector straight up off the logic board.
      댓글 쓰기
    5. MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 23 단계, 이미지 1개 중 1개
      • Remove the following screws securing the subwoofer to the upper case:
      • One 3.8 mm Phillips screw
      • One 5 mm Phillips screw
      댓글 쓰기
    6. MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 24 단계, 이미지 2개 중 1개 MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 24 단계, 이미지 2개 중 2개
      • The subwoofer is still connected to the right speaker, so don't completely remove it just yet.
      • Lift the subwoofer off the optical drive, and set it above the computer.
      댓글 쓰기
    7. MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 25 단계, 이미지 2개 중 1개 MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 25 단계, 이미지 2개 중 2개
      • Remove the two 10 mm Phillips screws securing the camera cable bracket to the upper case.
      • The leftmost screw may remain captive in the camera cable.
      • Lift the camera cable bracket out of the upper case.
      댓글 쓰기
    8. MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 26 단계, 이미지 2개 중 1개 MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement: 26 단계, 이미지 2개 중 2개
      • Remove the three 2.5 mm Phillips screws securing the optical drive to the upper case.
      • Lift the optical drive from its right edge and pull it out of the computer.
      댓글 쓰기
    1. MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement, Remove the centre bracket: 27 단계, 이미지 2개 중 1개 MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement, Remove the centre bracket: 27 단계, 이미지 2개 중 2개
      • Rotate the top case so that it looks like the top case in the picture.
      • Remove the 10mm phillips #00 screw.
      • Remove the 5mm phillips #00 screw.
      • Remove and set aside the centre bracket.
      • The pictures are captured from a YouTube video, but it does show the correct screws and part to remove.
      댓글 쓰기
    2. MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement, Remove the keyboard backlight: 28 단계, 이미지 2개 중 1개 MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement, Remove the keyboard backlight: 28 단계, 이미지 2개 중 2개
      • Carefully peel the black keyboard backlight from the upper case and remove it.
      • It is best to start from the bottom right corner.
      • Slide a spudger under the bottom right corner and slide the spudger up the right hand side of the backlight.
      • Once you have the right hand side of the backlight loose, you can then use your fingers to gently peel the backlight from the keyboard.
      댓글 쓰기
    3. MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement, Remove the keyboard: 29 단계, 이미지 1개 중 1개
      • Two 3 mm PH00 screws from the power button.
      • Sixty-seven 2mm PH000 screws from the keyboard.
      • Gently lift out the keyboard (and the attached power button).
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 170명이 해당 안내서를 완성하였습니다.
작성자
16다른 기여자 명과 함께
David Fear
회원 가입일: 09/08/11
5,599 평판
안내서 6개를 작성함
Pickle IT - Gadget Repair Pickle IT - Gadget Repair 회원
Business
2 회원들
안내서 34개를 작성함
62가이드 댓글
Having just done this - successfully, I might add - I need to make this guide a little more clear:
Step 1: open the case. See every other tear down for the screw count.
Step 1A: remove the battery connection.
Step 2/3: remove the fan as instructed.
Step 3A: remove the optical drive. See the relevant tear down guide for specifics.
Step 3B: remove all of the connecters to the logic board: keyboard, backlight, trackpad, fan, speaker/subwoofer, battery status indicator, hard drive, optical drive, camera, display. See the logic board removal guide for more info.
Step 3C: remove the screws holding the DC-in board and the logic board. Remove the logic board.
The remaining steps are pretty OK. Buy a new backlight and diffuser panel along with your new KB.
Perry Schlanger - 답글 공유
This guide is not very good at all... terrible actually. It misses so many steps!
mark - 답글 공유
I successfully completed this yesterday. Having never done Mac repairs myself the difficulty level made me nervous, however don't be afraid to give it a go! There are lots of little screws and parts but its not hard, more fiddly.
In addition to the tools here consider getting some kind of segmented box or little containers to keep all the screws separate. Also when I opened it up my logic board was filthy with dust! Keep a microfiber cloth and perhaps a soft brush around the clean a little as you go.
Andi - 답글 공유
Where do you purchase the 13" Macbook / Macbook Pro (2009-2012) Keyboard? I can see the uppercase is for sale, but the guide is for just replacing the keyboard.
Rob Meidal - 답글 공유
Keyboards can be purchased from powerbookmedic, thebookyard, ebay and aliexpress.
David Fear - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 13
지난 7일: 73
지난 30일: 335
전체 시간: 289,563
