주요 콘텐츠로 건너뛰기
MacBook Pro 14" 2021 Speakers Replacement
필요한 것
  1. MacBook Pro 14" 2021 Speakers Replacement, Unfasten the lower case: 1 단계, 이미지 2개 중 1개 MacBook Pro 14" 2021 Speakers Replacement, Unfasten the lower case: 1 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    FixMat
    $31.41
    • Completely power off and unplug your MacBook Pro before you start. Close the screen and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove eight screws securing the lower case:
    • Four 9.3 mm screws
    • Four 5 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 14" 2021 Speakers Replacement, Unclip the lower case: 2 단계, 이미지 2개 중 1개 MacBook Pro 14" 2021 Speakers Replacement, Unclip the lower case: 2 단계, 이미지 2개 중 2개
    • Press a suction handle into place near the front edge of the lower case, between the screw holes.
    • Pull up on the suction handle to create a small gap under the lower case.
  3. MacBook Pro 14" 2021 Speakers Replacement, Release the right clips: 3 단계, 이미지 3개 중 1개 MacBook Pro 14" 2021 Speakers Replacement, Release the right clips: 3 단계, 이미지 3개 중 2개 MacBook Pro 14" 2021 Speakers Replacement, Release the right clips: 3 단계, 이미지 3개 중 3개
    • Insert an opening pick into the gap you just created.
    • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
    • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
  4. MacBook Pro 14" 2021 Speakers Replacement, Release the left clips: 4 단계, 이미지 3개 중 1개 MacBook Pro 14" 2021 Speakers Replacement, Release the left clips: 4 단계, 이미지 3개 중 2개 MacBook Pro 14" 2021 Speakers Replacement, Release the left clips: 4 단계, 이미지 3개 중 3개
    • Repeat the previous step on the other side, using an opening pick to to release the second clip.
  5. MacBook Pro 14" 2021 Speakers Replacement, Release the sliding clips: 5 단계, 이미지 3개 중 1개 MacBook Pro 14" 2021 Speakers Replacement, Release the sliding clips: 5 단계, 이미지 3개 중 2개 MacBook Pro 14" 2021 Speakers Replacement, Release the sliding clips: 5 단계, 이미지 3개 중 3개
    • Sliding clips along the back edge of the MacBook further secure the lower case. Separating these clips may require a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Firmly pull the lower case away from the back edge, one corner at a time, to disengage the sliding clips.
    • Keep the lower case flat to the MacBook. Don't pull upward until it's completely separated.
  6. MacBook Pro 14" 2021 Speakers Replacement, Remove the lower case: 6 단계, 이미지 3개 중 1개 MacBook Pro 14" 2021 Speakers Replacement, Remove the lower case: 6 단계, 이미지 3개 중 2개 MacBook Pro 14" 2021 Speakers Replacement, Remove the lower case: 6 단계, 이미지 3개 중 3개
    • Remove the lower case.
    • To reinstall the lower case:
    • Lay it down and align the sliding clips with the back edge of the MacBook. Press down on the lower case and slide it toward the back edge to engage the clips.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push.
    • Once the back corners of the lower case are secured and flush with the frame, press down along the middle of the lower case to engage the four remaining clips.
    • You'll hear and feel each clip snap into place.
  7. MacBook Pro 14" 2021 Speakers Replacement, Disconnect the battery board: 7 단계, 이미지 3개 중 1개 MacBook Pro 14" 2021 Speakers Replacement, Disconnect the battery board: 7 단계, 이미지 3개 중 2개 MacBook Pro 14" 2021 Speakers Replacement, Disconnect the battery board: 7 단계, 이미지 3개 중 3개
    • Peel back any tape covering the battery board data cable connector on the logic board.
  8. MacBook Pro 14" 2021 Speakers Replacement: 8 단계, 이미지 2개 중 1개 MacBook Pro 14" 2021 Speakers Replacement: 8 단계, 이미지 2개 중 2개
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
  9. MacBook Pro 14" 2021 Speakers Replacement: 9 단계, 이미지 2개 중 1개 MacBook Pro 14" 2021 Speakers Replacement: 9 단계, 이미지 2개 중 2개
    • Disconnect the battery board data cable by sliding it out from its socket on the logic board.
  10. MacBook Pro 14" 2021 Speakers Replacement, Unfasten the trackpad cable bracket: 10 단계, 이미지 1개 중 1개
    • Use a T3 Torx driver to remove the two 2.1 mm‑long screws securing the trackpad cable bracket to the logic board.
  11. MacBook Pro 14" 2021 Speakers Replacement, Remove the trackpad cable bracket: 11 단계, 이미지 2개 중 1개 MacBook Pro 14" 2021 Speakers Replacement, Remove the trackpad cable bracket: 11 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers, or your fingers, to remove the trackpad cable bracket.
  12. MacBook Pro 14" 2021 Speakers Replacement, Disconnect the trackpad cable: 12 단계, 이미지 2개 중 1개 MacBook Pro 14" 2021 Speakers Replacement, Disconnect the trackpad cable: 12 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry up and disconnect the trackpad cable's press connector secured to the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  13. MacBook Pro 14" 2021 Speakers Replacement, Reposition the trackpad cable: 13 단계, 이미지 2개 중 1개 MacBook Pro 14" 2021 Speakers Replacement, Reposition the trackpad cable: 13 단계, 이미지 2개 중 2개
    • The trackpad cable is lightly adhered to the frame.
    • Peel the trackpad cable away from the device, making sure to separate the adhesive.
  14. MacBook Pro 14" 2021 Speakers Replacement, Disconnect the battery board: 14 단계, 이미지 2개 중 1개 MacBook Pro 14" 2021 Speakers Replacement, Disconnect the battery board: 14 단계, 이미지 2개 중 2개
    • Peel back any tape covering the battery board data cable connector under the large pancake screw.
  15. MacBook Pro 14" 2021 Speakers Replacement: 15 단계, 이미지 2개 중 1개 MacBook Pro 14" 2021 Speakers Replacement: 15 단계, 이미지 2개 중 2개
  16. MacBook Pro 14" 2021 Speakers Replacement: 16 단계, 이미지 2개 중 1개 MacBook Pro 14" 2021 Speakers Replacement: 16 단계, 이미지 2개 중 2개
    • Disconnect the battery board data cable by sliding it out from its socket on the battery board.
  17. MacBook Pro 14" 2021 Speakers Replacement, Remove the data cable: 17 단계, 이미지 2개 중 1개 MacBook Pro 14" 2021 Speakers Replacement, Remove the data cable: 17 단계, 이미지 2개 중 2개
    • The battery board data cable is lightly adhered to the device.
    • Slide blunt nose tweezers under areas with adhesive to separate the cable from the device.
    • Remove the battery board data cable.
  18. MacBook Pro 14" 2021 Speakers Replacement, Unfasten the battery connector: 18 단계, 이미지 1개 중 1개
    • Use a T5 Torx driver to remove the 3.8 mm wide-head screw securing the battery power connector.
  19. MacBook Pro 14" 2021 Speakers Replacement, Disconnect the battery connector: 19 단계, 이미지 3개 중 1개 MacBook Pro 14" 2021 Speakers Replacement, Disconnect the battery connector: 19 단계, 이미지 3개 중 2개 MacBook Pro 14" 2021 Speakers Replacement, Disconnect the battery connector: 19 단계, 이미지 3개 중 3개
    • Use the flat end of your spudger to lift the battery connector away from the battery board, disconnecting the battery.
    • Lift the connector high enough that it doesn't accidentally make contact during the repair, but no more than 45 degrees to prevent damaging its hinge.
    • For added safety, place a barrier, such as a piece of a playing card, between the connector and board.
  20. MacBook Pro 14" 2021 Speakers Replacement, Disconnect the right speaker: 20 단계, 이미지 2개 중 1개 MacBook Pro 14" 2021 Speakers Replacement, Disconnect the right speaker: 20 단계, 이미지 2개 중 2개
    • Peel back the tape covering the right speaker ZIF connector.
  21. MacBook Pro 14" 2021 Speakers Replacement: 21 단계, 이미지 2개 중 1개 MacBook Pro 14" 2021 Speakers Replacement: 21 단계, 이미지 2개 중 2개
    • Use the pointed end of a spudger to gently pry up the locking flap on the right speaker ZIF connector.
  22. MacBook Pro 14" 2021 Speakers Replacement: 22 단계, 이미지 2개 중 1개 MacBook Pro 14" 2021 Speakers Replacement: 22 단계, 이미지 2개 중 2개
    • Disconnect the right speaker cable by sliding it out from its socket.
  23. MacBook Pro 14" 2021 Speakers Replacement, Disconnect the left speaker: 23 단계, 이미지 3개 중 1개 MacBook Pro 14" 2021 Speakers Replacement, Disconnect the left speaker: 23 단계, 이미지 3개 중 2개 MacBook Pro 14" 2021 Speakers Replacement, Disconnect the left speaker: 23 단계, 이미지 3개 중 3개
    • Follow the procedure in the previous three steps to disconnect the left speaker.
  24. MacBook Pro 14" 2021 Speakers Replacement, Apply isopropyl alcohol: 24 단계, 이미지 3개 중 1개 MacBook Pro 14" 2021 Speakers Replacement, Apply isopropyl alcohol: 24 단계, 이미지 3개 중 2개 MacBook Pro 14" 2021 Speakers Replacement, Apply isopropyl alcohol: 24 단계, 이미지 3개 중 3개
    • Apply a few drops of highly-concentrated isopropyl alcohol (>90%) in the gap between the speaker and the edge of the frame.
    • Wait for 1–2 minutes to allow time for the isopropyl alcohol to weaken the adhesive.
  25. MacBook Pro 14" 2021 Speakers Replacement, Separate the adhesive: 25 단계, 이미지 3개 중 1개 MacBook Pro 14" 2021 Speakers Replacement, Separate the adhesive: 25 단계, 이미지 3개 중 2개 MacBook Pro 14" 2021 Speakers Replacement, Separate the adhesive: 25 단계, 이미지 3개 중 3개
    • Insert the tip of an opening pick in the gap between the speaker and the edge of the frame.
    • Slide the opening pick along the edge of the speaker to slice the adhesive beneath it.
  26. MacBook Pro 14" 2021 Speakers Replacement: 26 단계, 이미지 2개 중 1개 MacBook Pro 14" 2021 Speakers Replacement: 26 단계, 이미지 2개 중 2개
    • Insert the tip of an opening pick in the gap between the battery and the speaker.
    • Pry up with the pick to separate the speaker from the frame.
    • Take care not to puncture the battery while you pry. If you're having difficulty prying up, apply a few more drops of isopropyl alcohol.
  27. MacBook Pro 14" 2021 Speakers Replacement: 27 단계, 이미지 2개 중 1개 MacBook Pro 14" 2021 Speakers Replacement: 27 단계, 이미지 2개 중 2개
    • Slide the pick along the edge of the speaker to separate the adhesive.
  28. MacBook Pro 14" 2021 Speakers Replacement, Remove the speaker: 28 단계, 이미지 3개 중 1개 MacBook Pro 14" 2021 Speakers Replacement, Remove the speaker: 28 단계, 이미지 3개 중 2개 MacBook Pro 14" 2021 Speakers Replacement, Remove the speaker: 28 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $5.99
    • Use your fingers to remove the speaker, making sure to peel off any remaining adhesive.
    • Repeat the loosening and separating process for the other speaker.
    • Use a pre-cut adhesive sheet, like Tesa Tape, to secure the speaker back to the frame.
    • Clean up any remaining adhesive from the frame before installing new adhesives.
결론
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 14" 2021 Answers community for help.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
213,032 평판
안내서 1,040개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,623개를 작성함
3가이드 댓글
The description up top alludes to having to remove the logic board + fans to replace the speakers, but that doesn't seem to be the case in the step by step. Can anyone who's completed this speaker replacement clear that up?
thardee - 답글
Hi thardee, thanks for pointing that out. You're right, the logic board and fans don't need to be removed to replace the speakers. I've removed that section from the description.
Chayton Ritter -
Can you be clear about what is considered the right speaker? From the images, it appears you are removing the left speaker, as it appears when using the laptop in normal orientation. Obviously, with the base removed and the batteries at the bottom, this will be on the right when working on the laptop. If I were to order a replacement for what I consider to be the right speaker (i.e. the one by my right hand when typing), what should I specify (or do they only come in pairs anyway)?
Tim Holmes - 답글
댓글 쓰기
조회 통계:
지난 24시간: 14
지난 7일: 99
지난 30일: 342
전체 시간: 12,353
