이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
Mac 전원을 켜고 Terminal/터미널을 시작하세요.
다음 명령을 복사하여 Terminal/터미널에 붙여 넣으세요 (또는 정확히 입력하세요).
sudo nvram AutoBoot=%00
[return]을 누르세요. 관리자 암호 입력 메시지가 나타나면 관리자 암호를 입력하고 [return]을 다시 누르세요. 참고: return 키는 ⏎ 또는 "enter/입력"으로 표시되어 있을 수도 있습니다.
sudo nvram AutoBoot=%03
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
이 단계에 사용된 도구:Magnetic Project Mat$19.95-
Close the display and flip the entire laptop upside-down.
Use a P5 Pentalobe driver to remove six screws securing the lower case, of the following lengths:
Four 4.7 mm screws
Two 6.6 mm screws
Press a suction handle into place near the front edge of the lower case, between the screw holes.
Lift up on the suction handle just enough to open a small gap under the lower case.
Slide the corner of an opening pick into the gap you just created underneath the lower case.
Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
Repeat the previous step on the opposite side, using your opening pick to release the second clip.
Lift the front edge of the lower case (the side opposite the display hinge) just enough to slide your fingertips underneath and get a good grip on it.
Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
Pull first at one corner, then the other.
Remove the lower case.
Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips. You should feel and hear them click into place.
The speaker is glued to the enclosure with really hard tape, so I used hair dryer to make it easier to take it off.
Use the hair dryer to heat the metal from the other side, next to the keyboard.
After that, insert a metal ruler between the speaker and the enclosure. Be careful not to damage the battery shells when you do that.
You can also try to use a guitar string on the rounded corner next to the battery.
It works best when you heat the case while trying to remove the speaker. Ask someone to hold the hair dryer while you pull.
Only apply as much heat as you need until the glue slightly loosens.
In my case, I used double-sided tape for this replacement. The most important thing in this step is not to make a gap when you cut and put it on the speaker. Even just a little gap will make sound distorted.
Also, I noticed the structural differences between 2016 and 2017models. The right one is 2017 model and the left one is 2016 model from iFixit. Sound absorbing material is slightly different as you can see at the third picture, but I couldn't tell the difference of sound quality.
다른 44명이 해당 안내서를 완성하였습니다.
댓글 26개
is battery draining is related to speaker replacement? as I get it’s not, but just wanted to double-check
I’ll need to do the same replacement after I’ve damaged my speaker when I was opening my MacBook to change thermal paste, so great news you can change to case after a repair like that, thank you
Has anyone done this repair and what there any problems?
I just did it and I did encounter one frustrating thing. In this tutorial it's not mentioned but I did unplug/pull out the power/data line or whatever it is in the middle of the machine. When I went to put it back in, the tab which is there so you can pull on it ripped off! So I was very scared I wasn't going to be able to hook it back in and with some frustration managed to get it. Just be very careful with every step of this process.
wangmeow -
Where can I buy the right-side speaker component, 2017 model? As you noted in the 3rd step section, you find the structural differences between 2016 and 2017models. When I search the 2017 model right-side speaker in ifixit. com here, the component seems to be only 2016 model as below:
MacBook Pro 15" Retina (Late 2016-2017) Right Speaker
Also, do you have a video tutorial of replacing speakers? If then, much appreciated!
