주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
MacBook Pro 15" Core Duo Model A1150 Battery Replacement
필요한 것
    1. MacBook Pro 15" Core Duo Model A1150 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 132명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개를 작성함
3가이드 댓글
Hello,
I have found a really important mistype, on this page.
I assume, that on the picture, those tools are not thumbs but the "Introduction" says so!!! Those are "finger" tools.
It can mislead persons like me also, with my 25 years old of highly educated professional tool user experience.
Please correct the tools down below.
With the thumb tool, i was unable unattach the battery from the case.
BR
Albert Einstein - 답글 공유
Indeed, executing the detachment process of the battery using "thumbs" is a highly risky operation only to be performed by well-trained thumb specialists. The use of other "fingers" is much more common, as it might induce fairly less risk of severe injuries or death. Also, "Fingers" have a sweet little picture illustrating the right tool to use. I changed the guide accordingly.
marmuc100 - 답글 공유
Thank you so much gentleman for your help.
I appreciate the professional answer and the correction.
From now on i can sleep well at nights.
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 19
지난 30일: 75
전체 시간: 118,530
