주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement
필요한 것
    1. MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
      • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
      • Eight 3.0 mm
      • Two 2.3 mm
      댓글 쓰기
    2. MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement: 2 단계, 이미지 1개 중 1개
      • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
      • Set the lower case aside.
      댓글 쓰기
    1. MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement, Battery Connector: 3 단계, 이미지 1개 중 1개
      • Peel back the warning label covering the battery connector.
      댓글 쓰기
    2. MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement: 4 단계, 이미지 2개 중 1개 MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement: 4 단계, 이미지 2개 중 2개
      • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
      • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
      댓글 쓰기
    1. MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement, AirPort/Camera Cable: 5 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board.
      • The cable connection points are fragile. Be careful to lift only on the connector, and not on the socket or cable.
      • To reconnect, align the connector carefully into position over the socket, and press it down firmly with the flat of your spudger.
      댓글 쓰기
    2. MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement: 6 단계, 이미지 1개 중 1개
      • Use the tip of a spudger to push the camera cable's plug toward the fan and out of its socket on the logic board.
      • The plug in the photo has six connections, but some models have twelve connections. The process of removing the plug from its socket is the same for both.
      • If the camera cable's plug won't come easily out of its socket on the logic board, fold back the rubber cover over the fan to gain access to the cable, then gently pull on the cable while using the spudger to gently push the plug out of its socket.
      • Be sure to push parallel to the board, first on one side, then the other, to slowly "walk" the plug out of its socket. Do not pry up, or you will damage the socket.
      댓글 쓰기
    3. MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement: 7 단계, 이미지 3개 중 1개 MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement: 7 단계, 이미지 3개 중 2개 MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement: 7 단계, 이미지 3개 중 3개
      • Insert the flat end of a spudger underneath the rubber heat sink cover on the right fan.
      • Slide the spudger underneath the length of the cover, releasing the adhesive.
      • Lift the cover and flip it back so that you can access the cables underneath.
      댓글 쓰기
    4. MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement: 8 단계, 이미지 3개 중 1개 MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement: 8 단계, 이미지 3개 중 2개 MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement: 8 단계, 이미지 3개 중 3개
      • Use your fingers to pull the AirPort/Camera cables up off the fan.
      • The cables are adhered to the fan, so peel them up carefully to avoid damaging them.
      • Carefully de-route the cables from the plastic cable guide.
      댓글 쓰기
    1. MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement, Display Assembly: 9 단계, 이미지 2개 중 1개 MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement, Display Assembly: 9 단계, 이미지 2개 중 2개
      • Use the flat end of a spudger to pry off the two rubber hinge covers, one from each end of the device.
      댓글 쓰기
    2. MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement: 10 단계, 이미지 2개 중 1개 MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement: 10 단계, 이미지 2개 중 2개
      • Remove the two 3.1 mm T5 Torx screws securing the aluminum hinge covers to the upper case.
      • Remove the two aluminum hinge brackets from the MacBook Pro.
      댓글 쓰기
    3. MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement: 11 단계, 이미지 3개 중 1개 MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement: 11 단계, 이미지 3개 중 2개 MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement: 11 단계, 이미지 3개 중 3개
      • Use the tip of a spudger to pry the display data cable lock and rotate it toward the DC-In side of the computer.
      • Pull the display data cable straight out of its socket on the logic board.
      • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
      댓글 쓰기
    4. MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement: 12 단계, 이미지 1개 중 1개
      • Remove four out of the six 5.3 mm T8 Torx screws securing the display to the upper case.
      • We purposely have you leave one screw attaching the display to the upper case to aid in future steps.
      • When reassembling, make sure that the screws go through the two grounding loops on the webcam/airport cable.
      댓글 쓰기
    5. MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement: 13 단계, 이미지 1개 중 1개
      • Open the MacBook Pro approximately 110 degrees, and place it sideways on the table, as shown.
      • While holding the display and upper case together with your left hand, remove the remaining T8 Torx screw from the lower (closer to the table) display bracket.
      댓글 쓰기
    6. MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement: 14 단계, 이미지 1개 중 1개
      • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
      • While holding the display and upper case together with your left hand, remove the remaining T8 Torx screw from the upper display bracket.
      댓글 쓰기
    7. MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement: 15 단계, 이미지 3개 중 1개 MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement: 15 단계, 이미지 3개 중 2개 MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement: 15 단계, 이미지 3개 중 3개
      • Grip both halves of the device, one in each hand.
      • Gently push forward on the bottom half of the device to detach it from the display assembly.
      • Carefully set each component aside, making sure to set down the lower half keyboard-side down.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 82명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Sam Goldheart
회원 가입일: 10/18/12
477,928 평판
안내서 538개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 67,270개를 작성함
13가이드 댓글
Do yourself a favor and order the tools along with your display. I made the mistake thinking the bottom case was a standard torx and was surprised. The tools were not available in the local stores. I ended up ordering all the tools by clicking on the link where you goto order the display where it adds all of them to the cart. The tools are high quality and include the convenient finger tip end that allows the screw to be turned while keeping the screw steady and pointed in the correct angle. I am very happy with the tools and the display. I broke my screen when it dropped 2 feet from a chair to a carpeted floor and broke the bottom left corner 2 months after the retina first came out. It was fine except the screen was black till midway between the apple menu icon and the first pull down menu in apps until the display started to flicker lately and turn all white periodically.
bill - 답글 공유
Is the T8 Torx Screwdriver absolutely required or can I make do with just the T5 Torx driver?
Michael A - 답글 공유
One other comment on the re-assembly. You can keep the three hinge screws loose and run your fingers down the seams on the two sides and front to align the display before tightening.
bill - 답글 공유
You'll need a T4 as well to get the little brackets beside the display brackets... can't remove the screen with them on.
kris - 답글 공유
How about replacing only the lcd/screen, not the entire display - is there a guide for that? How difficult is it?
Albert Braae - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 14
지난 30일: 86
전체 시간: 81,157
