주요 콘텐츠로 건너뛰기
MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement
필요한 것
  1. MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.0 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement: 2 단계, 이미지 1개 중 1개
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Set the lower case aside.
  3. MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement, Battery Connector: 3 단계, 이미지 1개 중 1개
    • Peel back the warning label covering the battery connector.
  4. MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement: 4 단계, 이미지 2개 중 1개 MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement: 4 단계, 이미지 2개 중 2개
    • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
    • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  5. MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement, Heat Sink: 5 단계, 이미지 3개 중 1개 MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement, Heat Sink: 5 단계, 이미지 3개 중 2개 MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement, Heat Sink: 5 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger underneath the rubber heat sink cover on the right fan.
    • Slide the spudger underneath the length of the cover, releasing the adhesive.
    • Lift the cover and rotate it off of the heat sink.
  6. MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement: 6 단계, 이미지 3개 중 1개 MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement: 6 단계, 이미지 3개 중 2개 MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement: 6 단계, 이미지 3개 중 3개
    • In the same manner described above, release the adhesive and flip back the heat sink cover on the left fan.
  7. MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the following ten screws securing the heat sink to the logic board:
    • Two 2.4 mm T5 Torx screws
    • Six 3.4 mm T5 Torx screws
    • One 5.2 mm Raised Head T5 Torx screw
    • One 3.5 mm T5 Torx screw
  8. MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement: 8 단계, 이미지 1개 중 1개
    • Grasping the heat sink from one side, lift the heat sink off of the MacBook Pro, pulling it free from the computer.
    • The thermal paste may make it difficult to remove the heat sink. Pull the heat sink off gently but forcefully to avoid damaging any components on the logic board.
    • When installing the new heat sink, do not forget to replace the thermal paste underneath the heat sink. See our Applying Thermal Paste guide for further instructions.
결론
다른 41명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Brett Hartt
회원 가입일: 04/12/10
131,185 평판
안내서 143개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,605개를 작성함
8가이드 댓글
would doing this void the warranty?
sakada - 답글
Hello everybody!!! I tried to follow this guide... I removed the bottom case, no problem... but when it was the time to remove the upper 2.4mm T5 torn screw... it stripped and now i cannot remove it! How can i remove that screw?
And if this is not enough one of the 3mm pentalobe screw of the bottom stripped too! so what can i do?!? please help me!
Sorry for my bad english
Shaggot96 - 답글
I'm sorry to hear that! Try checking out this stripped screw guide and reading through this Answers post. Hope this helps with your repair!
Sam Goldheart -
I won't call this moderate but rather easy instead, seems like ifixit expect that easy is something you just unplug without even open the computer
Benjamin H - 답글
Where can I get new screws if I want to replace them?
Boro J. - 답글
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 233
지난 30일: 617
전체 시간: 43,917
