주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement
필요한 것
    1. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
      • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
      • Eight 3.0 mm
      • Two 2.3 mm
      댓글 쓰기
    2. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 2 단계, 이미지 1개 중 1개
      • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
      • Set the lower case aside.
      댓글 쓰기
    1. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement, Battery Connector: 3 단계, 이미지 1개 중 1개
      • Peel back the warning label covering the battery connector.
      댓글 쓰기
    2. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 4 단계, 이미지 2개 중 1개 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 4 단계, 이미지 2개 중 2개
      • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
      • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
      댓글 쓰기
    1. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement, AirPort/Camera Cable: 5 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board.
      • The cable connection points are fragile. Be careful to lift only on the connector, and not on the socket or cable.
      • To reconnect, align the connector carefully into position over the socket, and press it down firmly with the flat of your spudger.
      댓글 쓰기
    2. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 6 단계, 이미지 1개 중 1개
      • Use the tip of a spudger to push the camera cable's plug toward the fan and out of its socket on the logic board.
      • The plug in the photo has six connections, but some models have twelve connections. The process of removing the plug from its socket is the same for both.
      • If the camera cable's plug won't come easily out of its socket on the logic board, fold back the rubber cover over the fan to gain access to the cable, then gently pull on the cable while using the spudger to gently push the plug out of its socket.
      • Be sure to push parallel to the board, first on one side, then the other, to slowly "walk" the plug out of its socket. Do not pry up, or you will damage the socket.
      댓글 쓰기
    3. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 7 단계, 이미지 3개 중 1개 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 7 단계, 이미지 3개 중 2개 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 7 단계, 이미지 3개 중 3개
      • Insert the flat end of a spudger underneath the rubber heat sink cover on the right fan.
      • Slide the spudger underneath the length of the cover, releasing the adhesive.
      • Lift the cover and flip it back so that you can access the cables underneath.
      댓글 쓰기
    4. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 8 단계, 이미지 3개 중 1개 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 8 단계, 이미지 3개 중 2개 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 8 단계, 이미지 3개 중 3개
      • Use your fingers to pull the AirPort/Camera cables up off the fan.
      • The cables are adhered to the fan, so peel them up carefully to avoid damaging them.
      • Carefully de-route the cables from the plastic cable guide.
      댓글 쓰기
    1. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement, I/O Board Cable: 9 단계, 이미지 3개 중 1개 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement, I/O Board Cable: 9 단계, 이미지 3개 중 2개 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement, I/O Board Cable: 9 단계, 이미지 3개 중 3개
      • If your I/O Board cable's connectors have notches in the padding, you will need to release a locking lever underneath the notch in order to remove the cable. If this is the case, don't pry up on the connector until the levers are unlatched.
      • Using the flat end of a spudger, pry the I/O Board connector straight up out of its socket on the logic board.
      • During reassembly, connect this end first, as it does not flex.
      • In a similar fashion, remove the I/O Board cable connector from its socket on the I/O Board.
      • Remove the I/O Board cable from the MacBook Pro.
      댓글 쓰기
    1. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement, Airport Card: 10 단계, 이미지 1개 중 1개
      • Remove the single 2.9 mm T5 Torx screw securing the AirPort card to the logic board.
      댓글 쓰기
    2. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 11 단계, 이미지 2개 중 1개 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 11 단계, 이미지 2개 중 2개
      • Grasp the sides of the AirPort card and lift it up to a shallow angle (5-10˚) to separate the light adhesive adhering it to the logic board.
      • Pull the AirPort card parallel out of its connector on the logic board to remove it.
      댓글 쓰기
    3. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 12 단계, 이미지 2개 중 1개 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 12 단계, 이미지 2개 중 2개
      • Use the tip of a spudger to flip up the retaining flap on the right fan ribbon cable ZIF socket.
      • Be sure you are prying up on the hinged retaining flap, not the socket itself.
      • Starting at the top of the cable, slide a plastic opening tool under the right fan cable to free it from the logic board.
      • Use caution when freeing the cable, as it is strongly adhered to the logic board.
      댓글 쓰기
    4. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 13 단계, 이미지 1개 중 1개
      • Remove the following three screws securing the right fan to the logic board:
      • One 4.4 mm T5 Torx screw
      • One 3.9 mm T5 Wide Head Torx screw
      • One 5.0 mm T5 Torx screw with 2 mm collar
      댓글 쓰기
    5. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 14 단계, 이미지 1개 중 1개
      • Lift and remove the right fan out from the MacBook Pro.
      • When reinstalling the fan, it's easiest connect the fan ribbon cable as you drop the fan in place, rather than after you've installed the three fan screws.
      댓글 쓰기
    1. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement, Left Fan: 15 단계, 이미지 1개 중 1개
      • Use the flat end of a spudger to lift the rubber heat sink cover up off the left fan.
      댓글 쓰기
    2. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 16 단계, 이미지 1개 중 1개
      • Remove the following three screws securing the left fan to the logic board:
      • One 4.4 mm T5 Torx screw with 2 mm collar
      • When reinstalling the fan and its screws, don't fully torque the screws until you've first installed all of them loosely, so that the fan can move a little and position itself properly as you insert the screws into their threaded standoffs.
      댓글 쓰기
    3. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 17 단계, 이미지 3개 중 1개 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 17 단계, 이미지 3개 중 2개 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 17 단계, 이미지 3개 중 3개
      • Use the tip of a spudger to flip up the retaining flap on the left fan ribbon cable ZIF socket.
      • Starting at the top of the cable, slide a plastic opening tool under the left fan cable to free it from the logic board.
      • Use caution when freeing the cable, as it is strongly adhered to the logic board. If necessary, use an iOpener or hair dryer to heat the cable in order to soften the adhesive and make it easier to remove.
      • Lift the left fan out of the device.
      • When reinstalling the fan, it's easier to connect the fan ribbon cable as you drop the fan in place, rather than after you've installed the three fan screws.
      댓글 쓰기
    1. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement, SSD: 18 단계, 이미지 1개 중 1개
      • Remove the single 3.1 mm T5 Torx screw securing the SSD to the logic board.
      댓글 쓰기
    2. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 19 단계, 이미지 2개 중 1개 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 19 단계, 이미지 2개 중 2개
      • Slightly lift the rightmost side of the SSD and firmly slide it straight away out of its socket on the logic board.
      댓글 쓰기
    1. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement, I/O Board: 20 단계, 이미지 2개 중 1개 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement, I/O Board: 20 단계, 이미지 2개 중 2개
      • Use the tip of a spudger to flip up the I/O board data cable lock and rotate it toward the battery side of the computer.
      • Use the flat end of a spudger to slide the I/O board data cable straight out of its socket on the logic board.
      • Do not lift up on the I/O board data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
      댓글 쓰기
    2. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 21 단계, 이미지 3개 중 1개 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 21 단계, 이미지 3개 중 2개 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 21 단계, 이미지 3개 중 3개
      • Remove the two 3.1 mm T5 Torx screws securing the I/O board to the logic board.
      • On some models, also removing the silver 3.5 mm T5 Torx screw from the heatsink can aid in I/O board removal.
      • Carefully lift the I/O board and remove it from the lower case.
      댓글 쓰기
    1. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement, Logic Board Assembly: 22 단계, 이미지 1개 중 1개
      • Use the flat end of a spudger to pry the headphone jack connector up from its socket on the logic board.
      댓글 쓰기
    2. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 23 단계, 이미지 2개 중 1개 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 23 단계, 이미지 2개 중 2개
      • Use the flat end of a spudger to pry the left speaker connector up and out of its socket on the logic board.
      • Use the tip of a spudger to pry the right speaker connector up and out of its socket on the logic board
      • Be sure to pry on the cable head, and not on the socket itself. Prying on the socket may cause it to separate from the logic board.
      댓글 쓰기
    3. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 24 단계, 이미지 1개 중 1개
      • Peel back any tape covering the keyboard ribbon cable connector.
      댓글 쓰기
    4. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 25 단계, 이미지 3개 중 1개 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 25 단계, 이미지 3개 중 2개 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 25 단계, 이미지 3개 중 3개
      • Use the flat end of a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
      • Pry only under the hinged retaining flap, not the socket itself, or you may break it off the board.
      • Use the flat end of a spudger to gently back the keyboard ribbon cable out of its socket by pushing first at one side, then the other.
      댓글 쓰기
    5. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 26 단계, 이미지 1개 중 1개
      • Use the flat end of a spudger to pry the trackpad ribbon cable connector up from its socket on the logic board.
      댓글 쓰기
    6. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 27 단계, 이미지 1개 중 1개
      • Use the flat end of a spudger to pry the keyboard backlight connector up from its socket on the logic board.
      댓글 쓰기
    7. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 28 단계, 이미지 1개 중 1개
      • Use the tip of a spudger or your fingernail to flip up the retaining flap on the microphone ribbon cable ZIF socket.
      • Pull the microphone ribbon cable out of its socket.
      댓글 쓰기
    8. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 29 단계, 이미지 2개 중 1개 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 29 단계, 이미지 2개 중 2개
      • Use the tip of a spudger to pry the display data cable lock and rotate it toward the DC-In side of the computer.
      • Pull the display data cable straight out of its socket on the logic board.
      • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
      댓글 쓰기
    9. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 30 단계, 이미지 1개 중 1개
      • Use the flat end of a spudger to carefully pry off the rubber screw cap on the raised screw head near to the MagSafe 2 connector.
      댓글 쓰기
    10. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 31 단계, 이미지 1개 중 1개
      • Remove the following six screws securing the logic board to to the upper case:
      • One 2.6 mm T5 Torx screw
      • Two 5.8 mm T5 Torx screws
      • One 3.8 mm T5 Torx screw
      • One 5.2 mm Raised Head T5 Torx screw
      • One 3.5 mm Silver T5 Torx screw
      댓글 쓰기
    11. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 32 단계, 이미지 3개 중 1개 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 32 단계, 이미지 3개 중 2개 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 32 단계, 이미지 3개 중 3개
      • Lifting from the side nearest the battery, rotate the logic board toward the top of the MacBook Pro.
      • Using the flat end of a spudger, carefully push the MagSafe 2 connector out of its socket on the bottom of the logic board.
      • When reinstalling the logic board, check the cables at the marked locations to make sure they don't get pinned underneath the logic board.
      • Clockwise from top: keyboard, trackpad, battery, right speaker, keyboard backlight, display, microphone, headphone jack, left speaker.
      댓글 쓰기
    12. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 33 단계, 이미지 1개 중 1개
      • Remove the logic board assembly from the MacBook Pro.
      댓글 쓰기
    1. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement, Heat Sink: 34 단계, 이미지 2개 중 1개 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement, Heat Sink: 34 단계, 이미지 2개 중 2개
      • Remove the following eight screws securing the heat sink to the logic board:
      • Two 2.4 mm T5 screws
      • Six 3.4 mm T5 screws
      • Grip both ends of the heat sink and lift it up from the logic board.
      • When installing the new heat sink, do not forget to replace the thermal paste underneath the heat sink.
      댓글 쓰기
    1. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement, Logic Board: 35 단계, 이미지 2개 중 1개 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement, Logic Board: 35 단계, 이미지 2개 중 2개
      • Use the tip of a spudger to flip up the metal retaining flap on the HDMI data transfer cable.
      • Gently pull the HDMI data transfer cable straight out of its socket on the logic board.
      댓글 쓰기
    2. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: 36 단계, 이미지 1개 중 1개
      • Logic board remains.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 92명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Brett Hartt
회원 가입일: 04/12/10
132,286 평판
안내서 144개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 37,992개를 작성함
4가이드 댓글
Seriously &&^& these apple screws glued with the power of a thousand suns litterally ruined 4 of the case screws getting the back plate off.
icemac - 답글 공유
Perfect Guide. I'm impressed how easy it was to replace my logic board. It was my first Guide. You guys can change it to level 1, very easy, as long as the person does it without haste and with a light hand.
samoneda - 답글 공유
Thank you for the time and energy making this high quality guide. I used it to extract the logic board allowing me to to clean off some corrosion from liquid exposure. This made the process pretty painless. Discovered the battery was swollen as well so ordered a replacement.
jdv - 답글 공유
Considering how tedious and intimidating this job was, I couldn't dare re-soldering the gpu core if it weren’t for your guide. Thank you!
M S - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 23
지난 30일: 108
전체 시간: 121,768
