주요 콘텐츠로 건너뛰기
MacBook Pro 15" Touch Bar 2017 Lower Case Replacement
필요한 것
  1. MacBook Pro 15" Touch Bar 2017 Lower Case Replacement, Disable Auto Boot: 1 단계, 이미지 1/3 MacBook Pro 15" Touch Bar 2017 Lower Case Replacement, Disable Auto Boot: 1 단계, 이미지 2/3 MacBook Pro 15" Touch Bar 2017 Lower Case Replacement, Disable Auto Boot: 1 단계, 이미지 3/3
    • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
    • Power on your Mac and launch Terminal.
    • Copy and paste the following command (or type it exactly) into Terminal:
    • sudo nvram AutoBoot=%00
    • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
    • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
    • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
    • sudo nvram AutoBoot=%03
    • Completely power off and unplug your MacBook Pro before you begin.
    • Close the display and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove six screws securing the lower case, of the following lengths:
    • Four 4.7 mm screws
    • Two 6.6 mm screws
    • Note the orientation of the screws as you remove them—they need to be reinstalled at a slight angle.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 15" Touch Bar 2017 Lower Case Replacement: 3 단계, 이미지 1/2 MacBook Pro 15" Touch Bar 2017 Lower Case Replacement: 3 단계, 이미지 2/2
    • Press a suction handle into place near the front edge of the lower case, between the screw holes.
    • Lift up on the suction handle just enough to open a small gap under the lower case.
  3. MacBook Pro 15" Touch Bar 2017 Lower Case Replacement: 4 단계, 이미지 1/3 MacBook Pro 15" Touch Bar 2017 Lower Case Replacement: 4 단계, 이미지 2/3 MacBook Pro 15" Touch Bar 2017 Lower Case Replacement: 4 단계, 이미지 3/3
    • Slide the corner of an opening pick into the gap you just created underneath the lower case.
    • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
    • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
  4. MacBook Pro 15" Touch Bar 2017 Lower Case Replacement: 5 단계, 이미지 1/3 MacBook Pro 15" Touch Bar 2017 Lower Case Replacement: 5 단계, 이미지 2/3 MacBook Pro 15" Touch Bar 2017 Lower Case Replacement: 5 단계, 이미지 3/3
    • Repeat the previous step on the opposite side, using your opening pick to release the second clip.
  5. MacBook Pro 15" Touch Bar 2017 Lower Case Replacement: 6 단계, 이미지 1/1
    • Lift the front edge of the lower case (the side opposite the display hinge) just enough to slide your fingertips underneath and get a good grip on it.
    • Two additional hidden clips near the middle of the cover may pop free at this point, if they haven't already.
    • Don't lift very far and don't try to remove the lower case yet.
  6. MacBook Pro 15" Touch Bar 2017 Lower Case Replacement: 7 단계, 이미지 1/3 MacBook Pro 15" Touch Bar 2017 Lower Case Replacement: 7 단계, 이미지 2/3 MacBook Pro 15" Touch Bar 2017 Lower Case Replacement: 7 단계, 이미지 3/3
    • Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • Pull first at one corner, then the other.
    • Pull to the side—not up.
    • This may require a lot of force.
  7. MacBook Pro 15" Touch Bar 2017 Lower Case Replacement: 8 단계, 이미지 1/2 MacBook Pro 15" Touch Bar 2017 Lower Case Replacement: 8 단계, 이미지 2/2
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
    • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips. You should feel and hear them click into place.
결론
다른 14명이 해당 안내서를 완성하였습니다.
Jeff Suovanen
회원 가입일: 08/06/13
410,272 평판
안내서 259개 작성하였습니다
iFixit iFixit 회원
Community
141 회원들
안내서 17,757개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 12
7일 전: 79
30일 전: 327
전체 시간: 16,900
