주요 콘텐츠로 건너뛰기
MacBook Pro 16" 2021 Battery Replacement
단지 전제 조건
이 가이드는 전제 조건 전용 가이드입니다! 이 가이드는 다른 절차의 일부이며 단독으로 사용할 수 없습니다.
필요한 것
  1. MacBook Pro 16" 2021 Battery Replacement, Unfasten the battery board: 1 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Battery Replacement, Unfasten the battery board: 1 단계, 이미지 2개 중 2개
    • Use a T5 Torx driver to remove the two screws securing the battery board:
    • One 4.4 mm screw
    • One 3.8 mm screw
  2. MacBook Pro 16" 2021 Battery Replacement, Battery removal information: 2 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Battery Replacement, Battery removal information: 2 단계, 이미지 2개 중 2개
    • There are 14 total stretch release adhesive strips that secure the battery to the frame:
    • There are eight adhesive strips that are accessed from the bottom of the device.
    • There are six more adhesive strips accessed from the trackpad's location on the frame.
  3. MacBook Pro 16" 2021 Battery Replacement, Remove the stretch release adhesive: 3 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Battery Replacement, Remove the stretch release adhesive: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers, or your fingers, to grasp the black pull-tab on one of the adhesive strips.
  4. MacBook Pro 16" 2021 Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Pull the strip out slowly and steadily at a low angle. Give it plenty of time to stretch and un-stick from under the battery.
    • If the adhesive strip breaks off, try to retrieve it using your fingers or blunt tweezers, and continue pulling—but do not pry under the battery.
    • Repeat the process for all 14 stretch release adhesive strips.
  5. MacBook Pro 16" 2021 Battery Replacement, Remove the battery: 5 단계, 이미지 3개 중 1개 MacBook Pro 16" 2021 Battery Replacement, Remove the battery: 5 단계, 이미지 3개 중 2개 MacBook Pro 16" 2021 Battery Replacement, Remove the battery: 5 단계, 이미지 3개 중 3개
    • Slide the battery out of the frame to remove it.
결론
For optimal performance, calibrate your newly installed battery after completing this guide.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 16" 2021 Answers community for help.
작성자
1다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
212,632 평판
안내서 1,039개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,608개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 107
