주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Macintosh PowerBook 165c Display Replacement
필요한 것
    1. Macintosh PowerBook 165c Display Replacement, Display: 1 단계, 이미지 1개 중 1개
      • Orientate the computer right side up and open the display case to reveal the display.
      • Use a plastic opening tool to remove the two small plastic plugs located on the display case just below the display.
      댓글 쓰기
    2. Macintosh PowerBook 165c Display Replacement: 2 단계, 이미지 1개 중 1개
      • Use a T8 torx screwdriver to remove the two, 7.7mm long screws that were revealed by removing the plastic plugs.
      • Twist counterclockwise to remove the screw.
      • Caution: Once the screws are removed, the display is only held by two screws. Handle delicately.
      댓글 쓰기
    3. Macintosh PowerBook 165c Display Replacement: 3 단계, 이미지 1개 중 1개
      • Grip the two bottom corners of the plastic display cover and gently pull towards yourself so that the display cover rotates about the top of the display case.
      • The display cover should release from top.
      • Remove the display case.
      댓글 쓰기
    4. Macintosh PowerBook 165c Display Replacement: 4 단계, 이미지 1개 중 1개
      • Locate the black connector on the right of the display. The connector can be identified by the pink, light blue, and white wires protruding from its side.
      • Remove the black connector from the circuit board by pulling it away from its adapter.
      댓글 쓰기
    5. Macintosh PowerBook 165c Display Replacement: 5 단계, 이미지 1개 중 1개
      • Using a T8 torx screwdriver, remove the four, 10.8mm long screws from the corners of the display.
      • Caution: The display is no longer supported and must be handled with care.
      댓글 쓰기
    6. Macintosh PowerBook 165c Display Replacement: 6 단계, 이미지 1개 중 1개
      • Carefully tilt the display downwards and rest it on the keyboard.
      댓글 쓰기
    7. Macintosh PowerBook 165c Display Replacement: 7 단계, 이미지 3개 중 1개 Macintosh PowerBook 165c Display Replacement: 7 단계, 이미지 3개 중 2개 Macintosh PowerBook 165c Display Replacement: 7 단계, 이미지 3개 중 3개
      • Locate the orange ribbon cable on the back of the display.
      • Open the white tab fastener by pulling it outward.
      • Remove the orange ribbon cable by gently pulling it away from the opened tab fastener.
      • The display is now free.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jason
회원 가입일: 10/12/11
110 평판
안내서 4개를 작성함
Cal Poly, Team 6-3, Regan Fall 2011 Cal Poly, Team 6-3, Regan Fall 2011 회원
CPSU-REGAN-F11S6G3
4 회원들
안내서 95개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 50
전체 시간: 3,008
