주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Macintosh PowerBook 165c Floppy Drive Replacement
필요한 것
    1. Macintosh PowerBook 165c Floppy Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Orient the computer so the battery is facing you.
      • Slide the gray plastic battery cover to the right.
      댓글 쓰기
    2. Macintosh PowerBook 165c Floppy Drive Replacement: 2 단계, 이미지 1개 중 1개
      • Pull the battery toward yourself until it is fully detached.
      댓글 쓰기
    1. Macintosh PowerBook 165c Floppy Drive Replacement, Input/Output Door: 3 단계, 이미지 1개 중 1개
      • Orient the computer right side up with the rear facing you.
      • Open the Input/Output (I/O) door.
      댓글 쓰기
    2. Macintosh PowerBook 165c Floppy Drive Replacement: 4 단계, 이미지 1개 중 1개
      • Carefully bend the door into an arch until one of the pins releases from its slot.
      • Once one of the pins is free, remove the I/O door from the computer.
      댓글 쓰기
    1. Macintosh PowerBook 165c Floppy Drive Replacement, Lower Case: 5 단계, 이미지 1개 중 1개
      • Orient the computer with the bottom facing up and rear facing you. You should be able to read the Macintosh label in this position.
      댓글 쓰기
    2. Macintosh PowerBook 165c Floppy Drive Replacement: 6 단계, 이미지 1개 중 1개
      • Use a T8 torx screwdriver to remove the 6.8mm long screw above and to the right of the modem jack.
      • Twist counter clockwise to remove the screw.
      댓글 쓰기
    3. Macintosh PowerBook 165c Floppy Drive Replacement: 7 단계, 이미지 1개 중 1개
      • Use a T10 torx screwdriver to remove the four, 18mm long screws from the lower case.
      댓글 쓰기
    4. Macintosh PowerBook 165c Floppy Drive Replacement: 8 단계, 이미지 2개 중 1개 Macintosh PowerBook 165c Floppy Drive Replacement: 8 단계, 이미지 2개 중 2개
      • Place your hands on the lower case, just above the I/O panel, and slowly lift the lower case a few inches above the main body of the computer.
      • Release the large, gray interconnect ribbon cable just behind the I/O panel.
      • Caution: Lower case cannot be fully removed until two plastic clips in the front corners are released. See the following step for details.
      댓글 쓰기
    5. Macintosh PowerBook 165c Floppy Drive Replacement: 9 단계, 이미지 2개 중 1개 Macintosh PowerBook 165c Floppy Drive Replacement: 9 단계, 이미지 2개 중 2개
      • Place your thumb on the upper case, inside the empty battery slot, and your index finger near your thumb on the left side of the lower case.
      • Pinch your thumb and index finger towards each other to release the clip. Without releasing pressure on the pinch grip, use your index finger to push the lower case upwards.
      • Lift the lower case to remove it.
      댓글 쓰기
    1. Macintosh PowerBook 165c Floppy Drive Replacement, Modem Card: 10 단계, 이미지 1개 중 1개
      • Orient the computer so the ports are facing you.
      댓글 쓰기
    2. Macintosh PowerBook 165c Floppy Drive Replacement: 11 단계, 이미지 2개 중 1개 Macintosh PowerBook 165c Floppy Drive Replacement: 11 단계, 이미지 2개 중 2개
      • Locate the Modem Card on the lower case.
      • Use a T8 torx screwdriver to remove the two, 7.7mm long screws from the two corners.
      • The modem card is an optional component on the Macintosh 165c, and may not be included in all devices.
      댓글 쓰기
    3. Macintosh PowerBook 165c Floppy Drive Replacement: 12 단계, 이미지 1개 중 1개
      • Lift the modem card directly upward until it releases from the connector.
      • If the modem card is difficult to remove, gently jostle it back and forth as you lift up.
      댓글 쓰기
    1. Macintosh PowerBook 165c Floppy Drive Replacement, RAM and PSRAM Expansion Card: 13 단계, 이미지 2개 중 1개 Macintosh PowerBook 165c Floppy Drive Replacement, RAM and PSRAM Expansion Card: 13 단계, 이미지 2개 중 2개
      • Locate and lift ram card directly up until connector releases.
      • Move the card back and forth gently if the connector does not release immediately.
      댓글 쓰기
    2. Macintosh PowerBook 165c Floppy Drive Replacement: 14 단계, 이미지 2개 중 1개 Macintosh PowerBook 165c Floppy Drive Replacement: 14 단계, 이미지 2개 중 2개
      • Locate and lift the PSRAM expansion card vertically until connector releases.
      • If the PSRAM expansion card is difficult to remove, gently jostle it back and forth as you lift up.
      • The PSRAM expansion card is an optional component, and may not be included in all devices.
      댓글 쓰기
    1. Macintosh PowerBook 165c Floppy Drive Replacement, Daughterboard: 15 단계, 이미지 1개 중 1개
      • Use T8 torx screwdriver to remove four, 7.7mm long screws from the perimeter of the daughterboard.
      댓글 쓰기
    2. Macintosh PowerBook 165c Floppy Drive Replacement: 16 단계, 이미지 1개 중 1개
      • Life the daughterboard directly up to remove it from the connector.
      • If the daughterboard does not easily release from the connector, gently jostle it back and forth as you lift up.
      댓글 쓰기
    1. Macintosh PowerBook 165c Floppy Drive Replacement, Floppy Drive: 17 단계, 이미지 1개 중 1개
      • Use a T8 torx screwdriver to remove the five, 6.8mm long screws on the drive retainer.
      댓글 쓰기
    2. Macintosh PowerBook 165c Floppy Drive Replacement: 18 단계, 이미지 3개 중 1개 Macintosh PowerBook 165c Floppy Drive Replacement: 18 단계, 이미지 3개 중 2개 Macintosh PowerBook 165c Floppy Drive Replacement: 18 단계, 이미지 3개 중 3개
      • Orient the computer so the plastic clip in top left corner of the lower case is facing you. Release the clip by lifting the retainer. You may need to adjust the hard drive to remove the retainer.
      • Lift the drive retainer out.
      댓글 쓰기
    3. Macintosh PowerBook 165c Floppy Drive Replacement: 19 단계, 이미지 2개 중 1개 Macintosh PowerBook 165c Floppy Drive Replacement: 19 단계, 이미지 2개 중 2개
      • Open the white lock out tab to the right of the floppy drive.
      • Remove the white floppy drive ribbon cable by gently pulling it away from the opened tab fastener.
      댓글 쓰기
    4. Macintosh PowerBook 165c Floppy Drive Replacement: 20 단계, 이미지 1개 중 1개
      • Lift the floppy drive upwards to remove it.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Adam
회원 가입일: 10/12/11
1 평판
안내서 4개를 작성함
Cal Poly, Team 6-3, Regan Fall 2011 Cal Poly, Team 6-3, Regan Fall 2011 회원
CPSU-REGAN-F11S6G3
4 회원들
안내서 24개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 27
전체 시간: 1,483
