주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Macintosh Powerbook 5300cs Trackpad Replacement
필요한 것
    1. Macintosh Powerbook 5300cs Trackpad Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • The battery compartment is located in the front-right side of the laptop.
      댓글 쓰기
    2. Macintosh Powerbook 5300cs Trackpad Replacement: 2 단계, 이미지 1개 중 1개
      • To insert the battery, gently slide it into the compartment until it clicks in place.
      • To remove, slide the button highlighted in the red rectangle to the right to release the battery and slide it from the compartment.
      댓글 쓰기
    1. Macintosh Powerbook 5300cs Trackpad Replacement, Keyboard: 3 단계, 이미지 1개 중 1개
      • With the laptop upside down and with the battery removed, use a Torx #9 screw driver to remove the three .84 in. screws shown.
      댓글 쓰기
    2. Macintosh Powerbook 5300cs Trackpad Replacement: 4 단계, 이미지 2개 중 1개 Macintosh Powerbook 5300cs Trackpad Replacement: 4 단계, 이미지 2개 중 2개
      • Carefully pull up on the front of the keyboard to pop it out from the case.
      • Then slide the back out so the keyboard becomes nearly free.
      댓글 쓰기
    3. Macintosh Powerbook 5300cs Trackpad Replacement: 5 단계, 이미지 3개 중 1개 Macintosh Powerbook 5300cs Trackpad Replacement: 5 단계, 이미지 3개 중 2개 Macintosh Powerbook 5300cs Trackpad Replacement: 5 단계, 이미지 3개 중 3개
      • Disconnect the ribbon that is connecting the keyboard to the rest of the computer.
      • Pull the keyboard out and repair or replace as needed.
      댓글 쓰기
    1. Macintosh Powerbook 5300cs Trackpad Replacement, Trackpad: 6 단계, 이미지 3개 중 1개 Macintosh Powerbook 5300cs Trackpad Replacement, Trackpad: 6 단계, 이미지 3개 중 2개 Macintosh Powerbook 5300cs Trackpad Replacement, Trackpad: 6 단계, 이미지 3개 중 3개
      • Remove the front plastic panel of the laptop by carefully lifting it up and forward.
      • There will be another another ribbon cable connecting the trackpad; use caution when lifting the front panel.
      댓글 쓰기
    2. Macintosh Powerbook 5300cs Trackpad Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the orange stripped ribbon that connects the trackpad to the device by carefully pulling the ribbon from its connector up and out.
      댓글 쓰기
    3. Macintosh Powerbook 5300cs Trackpad Replacement: 8 단계, 이미지 2개 중 1개 Macintosh Powerbook 5300cs Trackpad Replacement: 8 단계, 이미지 2개 중 2개
      • With a Torx #9 screwdriver, remove the two .20 in. screws circled in red that are holding the trackpad in place. This will disconnect the mouse button.
      • Following this action, disconnect the ribbon highlighted with the red rectangle connecting the trackpad to the laptop.
      • Remove the mouse button by sliding it out from the top of the orange ribbon.
      댓글 쓰기
    4. Macintosh Powerbook 5300cs Trackpad Replacement: 9 단계, 이미지 1개 중 1개
      • The trackpad can now be removed from the laptop. Adjust the trackpad as needed.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Ronan
회원 가입일: 10/10/11
72 평판
안내서 4개를 작성함
Cal Poly, Team 6-1, Regan Fall 2011 Cal Poly, Team 6-1, Regan Fall 2011 회원
CPSU-REGAN-F11S6G1
4 회원들
안내서 40개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 51
전체 시간: 1,552
