주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Magic Bullet NutriBullet Power Cord Replacement
필요한 것
    1. Magic Bullet NutriBullet Power Cord Replacement, Power Cord: 1 단계, 이미지 2개 중 1개 Magic Bullet NutriBullet Power Cord Replacement, Power Cord: 1 단계, 이미지 2개 중 2개
      • Before beginning, make sure the device is unplugged.
      • With a Phillips head #2 screwdriver, begin unscrewing the four 10mm screws located on the bottom of the power base.
      댓글 쓰기
    2. Magic Bullet NutriBullet Power Cord Replacement: 2 단계, 이미지 1개 중 1개
      • Once the screws are removed, pull the plastic base up gently.
      • Once the plastic base is removed, there is a fan located in the center of the powerbase. Make sure the cord does not get caught or frayed by the fan.
      댓글 쓰기
    3. Magic Bullet NutriBullet Power Cord Replacement: 3 단계, 이미지 1개 중 1개
      • Gently lift the power cord from its side slot and place it to the side.
      댓글 쓰기
    4. Magic Bullet NutriBullet Power Cord Replacement: 4 단계, 이미지 2개 중 1개 Magic Bullet NutriBullet Power Cord Replacement: 4 단계, 이미지 2개 중 2개
      • With the Phillips head #2 screwdriver, remove the two 10mm screws that secure the white bracket.
      • The white safety bracket holds the cord down. After removing it, the cord will be free.
      댓글 쓰기
    5. Magic Bullet NutriBullet Power Cord Replacement: 5 단계, 이미지 1개 중 1개
      • After removing the gray base and silver casing, the wires will now be free and you will have easy access to them.
      • Gently pull out the two plastic covers at the end of the wires.
      댓글 쓰기
    6. Magic Bullet NutriBullet Power Cord Replacement: 6 단계, 이미지 1개 중 1개
      • Use tape or clamps to hold the wires together for an easy soldering experience.
      • Using a soldering iron, solder your new wire to the red wire.
      댓글 쓰기
결론
Since this guide replacement requires cutting wires, if you want to reassemble this device, you must first re-solder new wires before following the steps backwards to reassemble the device.
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
13다른 기여자 명과 함께
Geary Yu
회원 가입일: 01/22/15
1,277 평판
안내서 3개를 작성함
Cal Poly, Team 19-8, Maness Winter 2015 Cal Poly, Team 19-8, Maness Winter 2015 회원
CPSU-MANESS-W15S19G8
4 회원들
안내서 54개를 작성함
7가이드 댓글
where am I going to be the magic bullet repair
Or
there a service center here in the philippines?
Thank u.
florentinokarenjoy24 - 답글 공유
Is there a service centre in Singapore?
I just bought the gadget in Melbourne (from Harvey Norman Nunawarding) last week. We used it yesterday but after one round of spinning, gadget went dead.
What could go round and to fix it at home?
Michael Lee - 답글 공유
Can I plug the Magic Bullet in 220v?
Sovelita Tenerife - 답글 공유
Where can I get a replacement cable from?
victoria hatton - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 26
지난 30일: 112
전체 시간: 17,569
