주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Magic Bullet NutriBullet Rubber Gasket Replacement
필요한 것
  1. Magic Bullet NutriBullet Rubber Gasket Replacement, Rubber Gasket: 1 단계, 이미지 1개 중 1개
    • Separate the blending blade lid from the cup.
    댓글 쓰기
  2. Magic Bullet NutriBullet Rubber Gasket Replacement: 2 단계, 이미지 2개 중 1개 Magic Bullet NutriBullet Rubber Gasket Replacement: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using tweezers, grab the gasket at the indented lip which is located on the side of the blending blade.
    • Slowly pry the rubber gasket up.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Geary Yu
회원 가입일: 01/22/15
1,277 평판
안내서 3개를 작성함
Cal Poly, Team 19-8, Maness Winter 2015 Cal Poly, Team 19-8, Maness Winter 2015 회원
CPSU-MANESS-W15S19G8
4 회원들
안내서 19개를 작성함
11가이드 댓글
The trouble is, this process doesn't work in reverse order as the gasket keeps popping up where you are not applying the pressure. You could do this all day and I'm sure it would be great therapy for OCD.
lizzywade888 - 답글 공유
I want to replace the rubber gasket. My trouble is I can't find a gasket that states it will fit this model. magic Bullet NUTRIBULLET model number NB-WL007-02 Can you tell me where to purchase this? Thanks!
Marcia Sikes
today_first@cox.net
todayfirst - 답글 공유
My understanding is that if it's leaking all the way into the base and not out the sides, it's likely not the main gasket (a faulty one of these would probably cause it to leak out the sides). This is a really good video that explains how to remove the blade and replace the washers that act as gaskets to stop liquid from dripping straight through the center/blade area.
https://www.youtube.com/watch?v=n0fiNRwh...
Tracy Hamilton - 답글 공유
Thanks a lot.
Kayla Martin - 답글 공유
lizzywad is correct. The %#*@ thing wont stay in, it keeps popping out.  What else can be done?
deborah blair - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 45
지난 30일: 181
전체 시간: 38,320
