주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Magic Trackpad Battery Replacement
필요한 것
  1. Magic Trackpad Battery Replacement, Batteries: 1 단계, 이미지 2개 중 1개 Magic Trackpad Battery Replacement, Batteries: 1 단계, 이미지 2개 중 2개
    • Use a spudger or coin to twist out the battery door.
    댓글 쓰기
  2. Magic Trackpad Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Slide out the two AA batteries.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Ronnie
회원 가입일: 10/22/12
3,851 평판
안내서 5개를 작성함
4가이드 댓글
Hello there, is the Trackpad destroyed by misplacing (wrong polarity) the batteries?
Toto1411 - 답글 공유
I recently found a Magic Trackpad on a junk pile, to find that the batteries are corroded and won’t come out.
I poured a small amount of isopropyl alcohol in the battery cylider, pried with a thin plastic pick and banged it against a table to get out the first battery, but the second one doesn’t want to move.
Any suggestions for how to get it out without destroying the device? The only thing I can think of would be to crazy-glue a thin rod to the top of the battery, maybe pour in some alcohol, and pull/wiggle the battery until it comes out. I’m afraid that any kind of stronger solvent will cause real damage.
Opinions?
shamino - 답글 공유
The best solvent for leaked alkaline batteries is… tap water!
michel.firholz - 답글 공유
I had corroded batteries in my Magic Keyboard. Exact same construction. I fashioned a thin blade from an aluminum can. It had enough column strength to slide between the battery and the aluminum battery compartment and with different solvents I was able to free the batteries. Now I have a trackpad that I am trying to recondition but not so easy. IPA and WD40 did not free the batteries this time, about to try dilute vinegar.
Eric Andersen - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 48
지난 30일: 217
전체 시간: 18,351
