주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Maingear Vector Laptop Screen Replacement
필요한 것
    • pull off the black bezel around the deges
    • it is held on by double-sided tape. be careful not to break the bezel it is a somewhat thin plastic sheet.
    댓글 쓰기
  1. 이 단계에 사용된 도구:
    • carefully pry up the bottom of the screen. there is double-sided tape holding it to the back.
    • pry on one side at a time slowly and once you can fit a pair of tweezers befind the screen grab the tape. when yo pull the tape it will come off like 3m command hooks
    • be careful not to rip the tape
    • the tape is in two vertical strips about an inch from the edge
    댓글 쓰기
    • the replacement screen is a lp156wfg(sp)(B2) on the maingear vector mg vctr001 1660ti from 2020
    댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. this is not a complete guide there is only enough info for you to know how to open it little steps are missing.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
djluke mon
회원 가입일: 04/18/22
97 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 48
전체 시간: 1,137
