주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Making Visible the Users Library Directory in OS X Lion
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
  1. Making Visible the Users Library Directory in OS X Lion, Making Visible the Users Library Directory in OS X Lion: 1 단계, 이미지 2개 중 1개 Making Visible the Users Library Directory in OS X Lion, Making Visible the Users Library Directory in OS X Lion: 1 단계, 이미지 2개 중 2개
    • Many Macintosh users were excited when OS X 10.7 (Lion) was released, but after using it for a short time, many users realized that something was missing from lion.
    • The users Library directory is not where it it should be, infact, it is nowhere to be found. Fortunately, it is very simple to bring back the disappearing Library.
    댓글 쓰기
  2. Making Visible the Users Library Directory in OS X Lion: 2 단계, 이미지 1개 중 1개
    • To begin the process, you will need to go to your Applications folder, which can be found in your Finder side bar.
    • Once in the Applications folder, you will want to find the Utilities folder.
    댓글 쓰기
  3. Making Visible the Users Library Directory in OS X Lion: 3 단계, 이미지 1개 중 1개
    • After navigating to the Utilities folder you will need to scroll down to find the Terminal application.
    댓글 쓰기
  4. Making Visible the Users Library Directory in OS X Lion: 4 단계, 이미지 2개 중 1개 Making Visible the Users Library Directory in OS X Lion: 4 단계, 이미지 2개 중 2개
    • Once you have opened Terminal, you will need to type chflags nohidden ~/Library/ and then press Enter.
    • This will immediately make your Library folder visible under your user.
    댓글 쓰기
  5. Making Visible the Users Library Directory in OS X Lion: 5 단계, 이미지 1개 중 1개
    • Once you have finished with Terminal, type exit to end your terminal processes. After you have typed this and hit enter you may quit out of Terminal.
    댓글 쓰기
  6. Making Visible the Users Library Directory in OS X Lion: 6 단계, 이미지 1개 중 1개
    • To hide the Library folder, simply type chflags hidden ~/Library and press Enter.
    • Remember to type exit and press Enter before quitting Terminal.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Owen Cunneely
회원 가입일: 12/01/10
7,187 평판
안내서 1개를 작성함
Master Techs Master Techs 회원
Community
333 회원들
안내서 1,496개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 45
전체 시간: 1,706
