주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Marshal Woburn Top Control Panel Replacement
필요한 것
  1. Marshal Woburn Top Control Panel Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 Marshal Woburn Top Control Panel Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
    • Before starting, unplug the speaker from any power source. After unplugging the device, wait around 10 minutes before starting to let the capacitor fully discharge.
    • On a flat surface, orient the device so that the front grille is facing downward.
    • Using a Phillips #1 screwdriver, remove the ten outer 28.6 mm screws marked in red.
    • Remove the eight inner 28.6 mm screws with the Phillips #1 screwdriver.
    댓글 쓰기
  2. Marshal Woburn Top Control Panel Replacement: 2 단계, 이미지 2개 중 1개 Marshal Woburn Top Control Panel Replacement: 2 단계, 이미지 2개 중 2개
    • Lift the back input board slightly above the back panel.
    • Rotate the input board so that you can slide it into the hole in the back panel that it came from.
    • Fully slide the input board through the back panel and set it down gently inside the speaker.
    댓글 쓰기
  3. Marshal Woburn Top Control Panel Replacement: 3 단계, 이미지 1개 중 1개
    • Grab the panel by the large hole and lift one side until you can fit your hand under.
    • Use your hand to fully remove the back panel from the rest of the frame.
    댓글 쓰기
  4. Marshal Woburn Top Control Panel Replacement, I/O Board: 4 단계, 이미지 1개 중 1개
    • Disconnect the 5 wires circled in red from the back input board.
    • Grip and pull the connectors, not the wires.
    • There may be a little resistance when pulling on the connectors, but it should not require excessive force.
    댓글 쓰기
  5. Marshal Woburn Top Control Panel Replacement: 5 단계, 이미지 2개 중 1개 Marshal Woburn Top Control Panel Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the two 12.7 mm screws marked in red from the front of the back input panel with a Phillips #1 screwdriver.
    • Remove the power input from the back side of the panel.
    댓글 쓰기
  6. Marshal Woburn Top Control Panel Replacement: 6 단계, 이미지 1개 중 1개
    • Completely remove the I/O board and the attached plate.
    댓글 쓰기
  7. Marshal Woburn Top Control Panel Replacement, Top Control Panel: 7 단계, 이미지 1개 중 1개
    • Using a Philips #1 screwdriver, remove the eight 9.5 mm screws that are marked in red from the perimeter of the metal frame for the top control panel.
    댓글 쓰기
  8. Marshal Woburn Top Control Panel Replacement: 8 단계, 이미지 1개 중 1개
    • From the outside of the speaker, push down on the top control panel until you can feel the adhesive holding it to the frame start to loosen.
    • On the inside, make your way around the border of the top control panel and remove the adhesive until you can fully remove the panel from the frame.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
NateP
회원 가입일: 11/01/23
284 평판
안내서 2개를 작성함
UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023 UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023 회원
UMASSD-GULBRANDSEN-F23S2G4
3 회원들
안내서 12개를 작성함
1가이드 댓글
Hi. The on off switch has broken on my Woburn 2. Any ideas how to replace it and where I could buy a new switch? Thank you.
mathew jones - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 46
전체 시간: 1,043
