주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Marshall Kilburn Tweeters Replacement
필요한 것
    1. Marshall Kilburn Tweeters Replacement, Battery: 1 단계, 이미지 2개 중 1개 Marshall Kilburn Tweeters Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Place the unit face down as shown in the picture, exposing the battery cover.
      • Remove the two 4.0mm long screws holding the cover on using a T10 driver.
      댓글 쓰기
    2. Marshall Kilburn Tweeters Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the battery cover using a fingernail or nylon spudger.
      댓글 쓰기
    3. Marshall Kilburn Tweeters Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the battery and unplug the power lead.
      댓글 쓰기
    1. Marshall Kilburn Tweeters Replacement, Power Switch: 4 단계, 이미지 3개 중 1개 Marshall Kilburn Tweeters Replacement, Power Switch: 4 단계, 이미지 3개 중 2개 Marshall Kilburn Tweeters Replacement, Power Switch: 4 단계, 이미지 3개 중 3개
      • Place speaker as shown in image and remove the four corner 45.5mm back cover screws with a Phillips #2 driver.
      • Using a Phillips #2 driver, remove the six remaining 21.5mm outer back cover screws.
      댓글 쓰기
    2. Marshall Kilburn Tweeters Replacement: 5 단계, 이미지 2개 중 1개 Marshall Kilburn Tweeters Replacement: 5 단계, 이미지 2개 중 2개
      • Remove the back cover by using the vent hole as a grip.
      • Gently pull out the back cover and let it hang on the side of the speaker that has the knobs and power switch.
      • Unplug the main power lead from the control board; this allows the back to be opened more, allowing easy access to the power switch.
      댓글 쓰기
    3. Marshall Kilburn Tweeters Replacement: 6 단계, 이미지 3개 중 1개 Marshall Kilburn Tweeters Replacement: 6 단계, 이미지 3개 중 2개 Marshall Kilburn Tweeters Replacement: 6 단계, 이미지 3개 중 3개
      • Pull the back cover attached to the motherboard to the side as shown in first image.
      • Remove the white insulator from the stereo speaker and place it to the side.
      댓글 쓰기
    4. Marshall Kilburn Tweeters Replacement: 7 단계, 이미지 2개 중 1개 Marshall Kilburn Tweeters Replacement: 7 단계, 이미지 2개 중 2개
      • Place the speaker up right, and unscrew the golden bolt around the power switch with your hands, or a wrench.
      • Gently pull out the power switch as shown in the image.
      댓글 쓰기
    5. Marshall Kilburn Tweeters Replacement: 8 단계, 이미지 3개 중 1개 Marshall Kilburn Tweeters Replacement: 8 단계, 이미지 3개 중 2개 Marshall Kilburn Tweeters Replacement: 8 단계, 이미지 3개 중 3개
      • Use a slim spudger to wedge out the four red wires attached to the power switch.
      댓글 쓰기
    1. Marshall Kilburn Tweeters Replacement, Main Speaker: 9 단계, 이미지 3개 중 1개 Marshall Kilburn Tweeters Replacement, Main Speaker: 9 단계, 이미지 3개 중 2개 Marshall Kilburn Tweeters Replacement, Main Speaker: 9 단계, 이미지 3개 중 3개
      • Unscrew the eight 22.5mm screws of the speaker cover and the device using a Phillips #2 screwdriver.
      • Gently push the speaker cover out of the stereo speaker.
      • Make sure to slowly push out the speaker cover, and not too far because it is still connected to the stereo speaker.
      댓글 쓰기
    2. Marshall Kilburn Tweeters Replacement: 10 단계, 이미지 3개 중 1개 Marshall Kilburn Tweeters Replacement: 10 단계, 이미지 3개 중 2개 Marshall Kilburn Tweeters Replacement: 10 단계, 이미지 3개 중 3개
      • Disconnect the blue wires connected to the tweeter.
      • Disconnect the yellow wires connected to the main speaker.
      • Disconnect the red wires connected to the second tweeter.
      댓글 쓰기
    3. Marshall Kilburn Tweeters Replacement: 11 단계, 이미지 2개 중 1개 Marshall Kilburn Tweeters Replacement: 11 단계, 이미지 2개 중 2개
      • Unscrew the four 13.5mm screws connecting the main speaker to the speaker cover, with a Phillips #2 screwdriver.
      댓글 쓰기
    1. Marshall Kilburn Tweeters Replacement, Tweeters: 12 단계, 이미지 1개 중 1개
      • Remove the four 13.5mm screws that are placed on the tweeters with a Phillips #2 screwdriver.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Brad Schiffner
회원 가입일: 01/14/19
112 평판
안내서 1개를 작성함
1가이드 댓글
And where do u but the woofer?
luis martinez - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 37
전체 시간: 3,502
