주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Marshall Stanmore II Power Switch Replacement
필요한 것
  1. Marshall Stanmore II Power Switch Replacement, Rear Panel: 1 단계, 이미지 2개 중 1개 Marshall Stanmore II Power Switch Replacement, Rear Panel: 1 단계, 이미지 2개 중 2개
    • Turn off the device and unplug the cable from the wall and the speaker.
    • Lay the speaker with the back panel facing up on a flat, stable work surface.
    댓글 쓰기
  2. Marshall Stanmore II Power Switch Replacement: 2 단계, 이미지 2개 중 1개 Marshall Stanmore II Power Switch Replacement: 2 단계, 이미지 2개 중 2개
    • Use a Phillips #2 screwdriver to remove the ten 20.5 mm screws that secure the rear panel to the chassis.
    댓글 쓰기
  3. Marshall Stanmore II Power Switch Replacement: 3 단계, 이미지 2개 중 1개 Marshall Stanmore II Power Switch Replacement: 3 단계, 이미지 2개 중 2개
    • Carefully lift the rear panel and let it rest on an object, like a stack of books, to avoid straining the cables.
    • Do not attempt to fully remove the panel, as this will damage the connections inside.
    댓글 쓰기
  4. Marshall Stanmore II Power Switch Replacement, Power Switch: 4 단계, 이미지 3개 중 1개 Marshall Stanmore II Power Switch Replacement, Power Switch: 4 단계, 이미지 3개 중 2개 Marshall Stanmore II Power Switch Replacement, Power Switch: 4 단계, 이미지 3개 중 3개
    • Locate the Power Switch PCB on the left-hand side above the subwoofer.
    • Use a Phillips #2 screwdriver to remove the two 10 mm screws that secure the PCB.
    • Because the space inside is somewhat cramped, consider using the iFixit 150 mm Flex Extension included in the iFixit Pro Tech Toolkit.
    댓글 쓰기
  5. Marshall Stanmore II Power Switch Replacement: 5 단계, 이미지 2개 중 1개 Marshall Stanmore II Power Switch Replacement: 5 단계, 이미지 2개 중 2개
    • Locate the PCB's black wire connector and gently disconnect it.
    • Do not pull on the wires.
    댓글 쓰기
  6. Marshall Stanmore II Power Switch Replacement: 6 단계, 이미지 3개 중 1개 Marshall Stanmore II Power Switch Replacement: 6 단계, 이미지 3개 중 2개 Marshall Stanmore II Power Switch Replacement: 6 단계, 이미지 3개 중 3개
    • Pull the PCB out of the mount.
    • Take care not to damage the rubber seal surrounding the switch base as depicted in picture two.
    • Rocking the PCB back and forth while pulling may help remove the module.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jacob Rose Parks
회원 가입일: 02/06/24
527 평판
안내서 4개를 작성함
3가이드 댓글
Hellooooo very good but were did you fint the eplace the power switch ?
Fred - 답글 공유
Where can buy on /off switch ?
Choi Kee - 답글 공유
On/off switch bar is broken
Choi Kee - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 33
지난 30일: 114
전체 시간: 2,879
