주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Marshall Stanmore II Subwoofer Assembly Replacement
필요한 것
  1. Marshall Stanmore II Subwoofer Assembly Replacement, Rear Panel: 1 단계, 이미지 2개 중 1개 Marshall Stanmore II Subwoofer Assembly Replacement, Rear Panel: 1 단계, 이미지 2개 중 2개
    • Turn off the device and unplug the cable from the wall and the speaker.
    • Lay the speaker with the back panel facing up on a flat, stable work surface.
    댓글 쓰기
  2. Marshall Stanmore II Subwoofer Assembly Replacement: 2 단계, 이미지 2개 중 1개 Marshall Stanmore II Subwoofer Assembly Replacement: 2 단계, 이미지 2개 중 2개
    • Use a Phillips #2 screwdriver to remove the ten 20.5 mm screws that secure the rear panel to the chassis.
    댓글 쓰기
  3. Marshall Stanmore II Subwoofer Assembly Replacement: 3 단계, 이미지 2개 중 1개 Marshall Stanmore II Subwoofer Assembly Replacement: 3 단계, 이미지 2개 중 2개
    • Carefully lift the rear panel and let it rest on an object, like a stack of books, to avoid straining the cables.
    • Do not attempt to fully remove the panel, as this will damage the connections inside.
    댓글 쓰기
  4. Marshall Stanmore II Subwoofer Assembly Replacement, Subwoofer Assembly: 4 단계, 이미지 3개 중 1개 Marshall Stanmore II Subwoofer Assembly Replacement, Subwoofer Assembly: 4 단계, 이미지 3개 중 2개 Marshall Stanmore II Subwoofer Assembly Replacement, Subwoofer Assembly: 4 단계, 이미지 3개 중 3개
    • Pull back the clear sheaths on the end of each wire to expose the terminals.
    • Using a pair of tweezers, or your fingernail, depress the small latch and gently pull the wire off of the metal tabs.
    • Failure to press the latch while pulling could damage the subwoofer and/or wires.
    댓글 쓰기
  5. Marshall Stanmore II Subwoofer Assembly Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the six 20.5 mm T20 Torx screws that secure the subwoofer to the housing.
    • The subwoofer assembly contains a very strong magnet, so the screwdriver and screws may occasionally stick to the side of the assembly.
    댓글 쓰기
  6. Marshall Stanmore II Subwoofer Assembly Replacement: 6 단계, 이미지 1개 중 1개
    • Carefully lift the subwoofer assembly away from the housing.
    댓글 쓰기
  7. Marshall Stanmore II Subwoofer Assembly Replacement: 7 단계, 이미지 1개 중 1개
    • Optional: Inspect the felt gasket on the speaker frame for any tears or foreign material.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Rebecca Arellano
회원 가입일: 02/05/24
232 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 62
전체 시간: 1,333
