주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Marshall Stanmore II Tweeter Assembly Replacement
필요한 것
    1. Marshall Stanmore II Tweeter Assembly Replacement, Rear Panel: 1 단계, 이미지 2개 중 1개 Marshall Stanmore II Tweeter Assembly Replacement, Rear Panel: 1 단계, 이미지 2개 중 2개
      • Turn off the device and unplug the cable from the wall and the speaker.
      • Lay the speaker with the back panel facing up on a flat, stable work surface.
      댓글 쓰기
    2. Marshall Stanmore II Tweeter Assembly Replacement: 2 단계, 이미지 2개 중 1개 Marshall Stanmore II Tweeter Assembly Replacement: 2 단계, 이미지 2개 중 2개
      • Use a Phillips #2 screwdriver to remove the ten 20.5 mm screws that secure the rear panel to the chassis.
      댓글 쓰기
    3. Marshall Stanmore II Tweeter Assembly Replacement: 3 단계, 이미지 2개 중 1개 Marshall Stanmore II Tweeter Assembly Replacement: 3 단계, 이미지 2개 중 2개
      • Carefully lift the rear panel and let it rest on an object, like a stack of books, to avoid straining the cables.
      • Do not attempt to fully remove the panel, as this will damage the connections inside.
      댓글 쓰기
    1. Marshall Stanmore II Tweeter Assembly Replacement, Tweeter Assembly: 4 단계, 이미지 2개 중 1개 Marshall Stanmore II Tweeter Assembly Replacement, Tweeter Assembly: 4 단계, 이미지 2개 중 2개
      • Carefully pull back the translucent plastic sheathing on the two silver tweeter connectors.
      댓글 쓰기
    2. Marshall Stanmore II Tweeter Assembly Replacement: 5 단계, 이미지 3개 중 1개 Marshall Stanmore II Tweeter Assembly Replacement: 5 단계, 이미지 3개 중 2개 Marshall Stanmore II Tweeter Assembly Replacement: 5 단계, 이미지 3개 중 3개
      • Using your fingernail or tweezers, apply precise pressure to the small latch in the middle of the connector and gently pull upwards to disconnect the connector.
      • Repeat for the second connector.
      댓글 쓰기
    3. Marshall Stanmore II Tweeter Assembly Replacement: 6 단계, 이미지 2개 중 1개 Marshall Stanmore II Tweeter Assembly Replacement: 6 단계, 이미지 2개 중 2개
      • Use a Torx T20 screwdriver to remove the three 20.5 mm screws that secure the tweeter.
      • Lift the tweeter assembly from its housing.
      댓글 쓰기
    4. Marshall Stanmore II Tweeter Assembly Replacement: 7 단계, 이미지 1개 중 1개
      • The felt seal is removable. If there is no seal on the tweeter, it may be stuck to the cutout on the speaker frame.
      • Repeat steps 4-6 to remove the second tweeter if necessary.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Jacob Rose Parks
회원 가입일: 02/06/24
527 평판
안내서 4개를 작성함
1가이드 댓글
Do you know the tweeter spec? Or similar brand to install?
Leonardo Hernández - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 38
전체 시간: 824
