주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Marshall Woburn Subwoofer Replacement
필요한 것
    1. Marshall Woburn Subwoofer Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 Marshall Woburn Subwoofer Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
      • Before starting, unplug the speaker from any power source. After unplugging the device, wait around 10 minutes before starting to let the capacitor fully discharge.
      • On a flat surface, orient the device so that the front grille is facing downward.
      • Using a Phillips #1 screwdriver, remove the ten outer 28.6 mm screws marked in red.
      • Remove the eight inner 28.6 mm screws with the Phillips #1 screwdriver.
      댓글 쓰기
    2. Marshall Woburn Subwoofer Replacement: 2 단계, 이미지 2개 중 1개 Marshall Woburn Subwoofer Replacement: 2 단계, 이미지 2개 중 2개
      • Lift the back input board slightly above the back panel.
      • Rotate the input board so that you can slide it into the hole in the back panel that it came from.
      • Fully slide the input board through the back panel and set it down gently inside the speaker.
      댓글 쓰기
    3. Marshall Woburn Subwoofer Replacement: 3 단계, 이미지 1개 중 1개
      • Grab the panel by the large hole and lift one side until you can fit your hand under.
      • Use your hand to fully remove the back panel from the rest of the frame.
      댓글 쓰기
    1. Marshall Woburn Subwoofer Replacement, I/O Board: 4 단계, 이미지 1개 중 1개
      • Disconnect the 5 wires circled in red from the back input board.
      • Grip and pull the connectors, not the wires.
      • There may be a little resistance when pulling on the connectors, but it should not require excessive force.
      댓글 쓰기
    2. Marshall Woburn Subwoofer Replacement: 5 단계, 이미지 2개 중 1개 Marshall Woburn Subwoofer Replacement: 5 단계, 이미지 2개 중 2개
      • Remove the two 12.7 mm screws marked in red from the front of the back input panel with a Phillips #1 screwdriver.
      • Remove the power input from the back side of the panel.
      댓글 쓰기
    3. Marshall Woburn Subwoofer Replacement: 6 단계, 이미지 1개 중 1개
      • Completely remove the I/O board and the attached plate.
      댓글 쓰기
    1. Marshall Woburn Subwoofer Replacement, Subwoofer: 7 단계, 이미지 1개 중 1개
      • Using a Phillips #1 screwdriver, remove the eight 15.8 mm screws attaching the subwoofers to the frame.
      댓글 쓰기
    2. Marshall Woburn Subwoofer Replacement: 8 단계, 이미지 1개 중 1개
      • Lift each subwoofer up and out of the case and remove them together.
      • This may require a little force.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Kenneth
회원 가입일: 10/29/23
174 평판
안내서 2개를 작성함
UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023 UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023 회원
UMASSD-GULBRANDSEN-F23S2G4
3 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 20
지난 30일: 75
전체 시간: 2,248
